What is this clip for?
RNEMTP
This clip came with my cs-vl OF router table. I’m assuming it clips to the smaller of the 2 hoses but idk where the other side clips.
It looks like it fits into the top of the aluminum extrusion around the outside of the VL.  See the V on the right side of your picture...that probably fits into the V notch on the top of the extrusion.
Thank you! Now I see. It won't work on my setup because I have the VL not the GE. The profiles on the VL are the same as the MFT/3. If it had just the v channel without the t-track below it, it would work. I don't really need it anyways because I am only using the OF module.
It works with the MFT/3 profile without problems, it only interacts with the V-grove.
It's a bith tricky to attach though (on both profiles), especially when new.
And when older... it gets a bit more brittle and then snaps when you try to attach it when it's cold  [blink]
Replacement part nr is 450158
