  • Start date Start date
onocoffee said:
I'm now envisioning a Centrotec awl...
Here's my version...an extra PZ1 bit that I really don't need, placed in a metal lathe and turned to a point. I did this to 4 each PZ1 bits and now have the awl bits scattered throughout my driver bit collections.
I keep 2 of them in separate Twin Boxes for convenience. Just make sure to install them with the point down.  [smile]
[attachimg=2]
[attachimg=3]
I once installed the CXS Jacob's chuck onto my Centrotec handle, put a drill bit in it, and used that to elongate out a couple of holes in a rubber door sweep that had an adjustable metal strap but only round mounting holes in the rubber.
I suppose I could have done the same with one of my centrotec drill bits with the centrotec chuck, now that I think about it, but I like those too much to subject them to that abuse.
In my defense, the kids were asleep and I was trying to keep the noise down.
My original was a Craftsman, with the wide stubby handle, like the shortest screwdriver, It was totally clear though, instead of the usual red and blue stripes.
I actually got a new one of those too, for about $5, as a back up [big grin]
After further reading, I think the Wera version is intended to be driven into leather. I assume for stitching?
Okay, I know, I know - before you get upset that I'm bringing such a tool into this palace, I think it's a good one.
My local Lowe's has little stations set up with impact drivers and drills from DeWalt, Kobalt, Flex and Skil. You'd think that Skil is just another low quality random tool, but whenever I'm there, I play around with the drills - drilling screws into pressure treated 4x4, extracting the screws and drilling holes. While the Kobalt feels cheap, the Skil PowerCore 12v has impressed me over and over again. Feels good in the hand, well balanced, sounds good, has good power and works very impressively on the demo stations.
So I was pretty surprised to see the drill, with single battery and charger, on sale for $40. And I decided to buy one today. At the shop, it still feels good and I'm going to use it alongside my other drills to see how it compares. I've got an old DeWalt DCD710, a used TXS and the current CXS12.
I figured, at the very least, I can place it as my in-house drill at the new (non-woodworking) shop. Or, if it really sucks, I have 30 days to return it.
My latest items have finally arrived for my rejuvenated shed table.
The dashboard hinge system arrived a week or 2 ago, i got a 1900 track last week, and the remaining items turned up both yesterday and today
some 40x80 extrusion and a Benchdogs fence with the new version of the quad fencedogs ( so i can remove the fence and dogs without having to remove the fence first)
Have almost finished drilling the 400 3mm holes 😬
Luckily tomorrow is a public holiday, so i might be able to finish all the 20mm holes, however this may depend on how bored it get.........as i really want to properly mount the extrusion and try the hinge and fence out.
I just purchased a pair of Buss fuses that are filled with sand. :ROFLMAO: :ROFLMAO: :ROFLMAO:
Most Fluke DMM's use at least one of these fuses but several other Fluke models that are more sensitive use 2 different sand filled fuses. The fuses are rated for 1000 volts at 11A and 1000 volts at 440 mA.
However this quote from Fluke is the interesting part of the story:
"This high-energy fuse is designed to protect a user from electric shock and burns. It does this by keeping the energy generated by an electrical short within the fuse enclosure. The fuse is built to limit the length of time the energy is applied and the amount of oxygen available for combustion.
The fuse is filled with sand to stop an electrical short. The sand will not only help absorb the shock energy created by the current overload, but also help with the high temperatures generated (up to 10,000 °F). The energy will melt the sand and turn it to glass
, helping smother a potential fireball by cutting off the available oxygen, further protecting the user."
Egg slicer because I broke my last one trying to slice something I shouldn’t have.
Slicer for the “shouldn’t have”.
The kitchen is as much my workshop as my shop.
Same here, but for some reason the missus gets annoyed with the tools and sawdust! ;-)
Gotta keep them out of the kitchen…..
My wife didn’t like the rebuilding of engines in the bedroom, must be a women thing, either did my mother.
I went to pickup a used Oneida Super Dust Deputy for a dust collection system I am slowly cobbling together and ended up also taking home a 1930s era Delta Double-Duty 14" Bandsaw...
@onocoffee The DD's are worth their weight in gold I reckon, amazing units! Congrats on the bandsaw too, if it's your first one you're in for a treat, they're absolutely invaluable once you get used to them!
It's my first larger bandsaw. I've got the benchtop Delta Shopmaster 9" - which has been a great small bandsaw. But I've been feeling I could use more power, so this came at just the right time.
I purchased a couple of rotary brushes for a metal/wood surfacer I have. The interesting part is that they have abrasive strips interleaved between the Scotch-Brite segments. Hopefully this will texture the metal surface better as the brushes with only Scotch-Brite segments, polish the metal surface rather than texture the surface. These will be used to straight-line stainless and aluminum plates.
Got a Makita 1/4" trim router, corded version (240V in UK). Trying to use the OF1400 to flush trim panels to supporting battens vertically on a wall was not easy (to put it mildly), the little Makita is great. Should have got one ages ago. But, I'd forgotten what using a router with no dust collection is like :( Time to break out the 3D printer ;)
Bob
Bob
You're on a slippery slope now, hard to stop at just one Makita trimmer Bob!
