  • Start date Start date
I thought that as well. Even my wife asked if Festool have a small router....
Bob
They do! And it's pretty sensational! The MFK700 which is the bee's knee's if you do edging, veneers, etc.
Actually they have two, but the other model takes a specific (almost unobtanium) cutter that's very expensive even by Festool's standards!
I purchased a couple of rotary brushes for a metal/wood surfacer I have. The interesting part is that they have abrasive strips interleaved between the Scotch-Brite segments. Hopefully this will texture the metal surface better as the brushes with only Scotch-Brite segments, polish the metal surface rather than texture the surface. These will be used to straight-line stainless and aluminum plates.
I think you are going to like these. I purchased a couple of small ones with a fixed shaft for some metal/paint prep. Very clean & even results.
Kind regards,
Oliver
I went out to buy 1 maybe two 1m clamps............and came home with this kit for $613
Worked out $20 cheaper per clamp as a kit, with the other stuff free ( technically)
The stands, joiner and tilting adaptors ( ive wanted all these for a bit) run up around $250 total from the online shop i normally use.
It did make gluing up one of my draws today a lot easier than doing it with only 2 clamps i had that fit
Well I'll add to the Bessey booty with these pump drywall supports, they're pretty slick. I'm hoping they'll turn some 2-person tasks into single person tasks. I also picked up the laser fixture that attaches to the STE300 poles. :cool:
The optional ceiling tripod attachment is pretty clever in that it is initially very small for easy storage and then when it's needed, the sections fan-out in a circular pattern and they're locked together with a hitch pin.
I forgot i had ordered some levers for the domino DF500, they arrived today, i believe both sizes required for the fence and plate, and a couple spare, they are a pull to rotate thing as well.
Also, the vacuum pad VC4 and switch arrived today, got to play with that little when i got home. Its got a pretty strong hold down using compressed air ( still have to get a couple of adapters to try with my vacuum pump).
Had i known how well it actually does hold, i would have gotten the double sided version. With the rubber setup up like in the pic on my table to avoid one of the holes, and then turned up side down, i was afraid i would break it before it let go of the table.
Here's a chart from Festool that gives you an idea on how strong the vacuum chuck can be using their pump...just a reference.
Some years ago I bought a pair of Japanese Vampliers, which were pretty cool and multifunctional. A short while ago I bought Knipex Twingrips, the smaller version, similar in size to the Vampliers. Loved them so bought the 8” version.
Just got a vintage Stabila level from an antique shop. It has embossed writing cast into the aluminium profile. I'd be curious to know how vintage this level is, if anyone has a clue.
Bob
IMG_20250706_144135.jpgIMG_20250706_144155.jpgIMG_20250706_144209.jpgIMG_20250706_144227.jpg
How are the tripod leg thingy working for Bessey poles? - I’m just looking into ordering one
Hey @FestitaMakool it's pretty slick. Like the ceiling support I mentioned in the post above, the tripod also folds up into a smaller package for storing. Just pull the quick-hitch pin and it fan-folds into a smaller item. Some tripod photos along with a shot of the laser level bracket.
Thanks a lot Cheese! I have the older, but still very good and versatile supports. I must order at least one a set of legs, and the laser/light/camera holder :giggle:
A new powered respirator. I always liked the Sundström SR500/SR570 combination, so I stuck to what I already knew. Sadly, you can buy some really nice Festool stuff for its price, but I have to take very good care of whatever is still functioning in my lungs. My pulmonologist isn't too happy with all that wood dust anyway. If all goes well I should receive the package tomorrow.
Last week I downloaded a Japanese Makita-catalogue, because I was curious about the 5-inch battery powered 'Skil saw' that Scott Brown bought in Japan, and I was flabbergasted by the immense amounts of products and varieties of such available in Nihon. Makes one wonder about the company policies concerning what to sell where…
