  • Start date Start date
Cheese said:
SRSemenza said:
Milwaukee 3 1/2" pipe cutter.  PVC or copper depending on the blade.
That's interesting, so you change out the blade for the material you're cutting?  I wonder why a single blade wouldn't work for both materials? They're both rather soft.
I like the capacity, I usually have to cut that diameter on the band saw or on the metal cold saw.
    I am not sure if the cutting edge is different or not. But the PVC disk is larger in diameter so that it will reach through the thick wall.  Yes, it is waaay better than sawing. That PVC  dust gets all over the place, even with DC, clings to things due to the static. Then you still have to clean up the cut edges.
    This type of cutter is nothing new but this Milwaukee is a very nice one. There are two different ones in with different cutting ranges. 1/2" - 2 5/8" and  1 5/8" - 3 5/8".
Three bitholders. One from Wiha, and two from Wera.
First, the Wiha 387:
[attachimg=2]
I bought this because it mechanically locks bits by pulling a collar forward. In some situations that just works better than using magnets. After using it a few times I can say I do like it, but for one thing. With a bit in the holder and the lock engaged, there is only a very small part of the bit that protrudes from the holder. This has already bitten me a few times with recessed screws where the hole was not large enough to accommodate the locking part of the bit holder.  [huh]
[attachimg=3]
Second, the ratcheting Wera 816RA:
[attachimg=4]
Well, I can be short about this one: this is a great piece of kit! I just works and it feels really sturdy. This might become my favorite screwdriver.  [big grin]
Third, a bit of a gamble, the Wera 826T:
[attachimg=5]
This one has a special feature in that you can speed up the revolutions by a factor of 4 by pressing a button on the back of the bitholder. It does this by engaging a small gearbox inside the handle. It does work as advertised. However.... even a little bit of torque will cause the gears to slip. [eek] So the "turbo" (which is what the T in 826T stands for) will be useful only when screwing something that has almost no friction. To illustrate this: just keeping the bit loosely between a thumb and finger is enough to stop the turbo. When this happens the gears just slip, so you can't even use it normally without the turbo action in such cases. To do that, you would have to press the turbo button again. My verdict: nice gadget, but not really useful in practise.  [unsure]
Hi!
As I haven't had a chance to play with the 826T yet, stupid question: Is it supposed to slip/ does it have a "safety clutch" so it can only be used for literally loose, turning? Or is it maybe broken?
Kind regards,
Oliver
Just checked Wera's description of the 826T, you're indeed supposed to de-activate the Turbo for "high" torque (14 Nm max.) applications. So it's really only free speed.
Kind regards,
Oliver
I got a second Kreg Multi-Mark.  I had been wanting to get another one for a while.
I discovered that the left "holster" slot on my Veritas apron is the perfect location for my first Kreg Multi-Mark.  I'm really liking the apron!
[attachimg=2]
Hi Oliver,
As you found out already, it is indeed supposed to slip when the torque becomes too large. I kinda knew that before I bought it (I read the information on their website before I ordered the bitholder). I just made the mistake of thinking that 14 Nm would be a bit more than this. My bad, not Wera's.
Today it was time to renew and add to my workwear..
A work kilt from Blaklader, the summer heat won’t be a hassle now!  [big grin]:
A definitely controversial piece of clothing for work. The kind lady behind the counter told me that you’d have to be a bold type to wear it, but you seems to be - and I said definitely!
It holds everything a pair of carpenters trousers would hold, including fasteners pockets and hammer.
A vest, again from blaklader, carpenters type with detachable fasteners pockets - this means I can use it for indoor use and for finer work as well. Holds huge amount of tools right at hand. There’s even side entrance pockets that you can stick in a CXS as well - in a ladder that’s perfect.
[attachimg=2]
And last, a Carhartt Bib Rugged Flex Rugby overall. It’s extremely comfortable. Definitely gonna be a favourite for general work, although it doesn’t hold too much tools, but chest pockets helps hips clear of bulging pockets.
[attachimg=3]
Got this for my little Makita router:
Comatic DC40
This is nothing I really needed, but brand new for $100 I couldn’t let it go..
Will be handy with it’s very small compact size, dampened handle and all. (It’s Makita’s CXT 10,8/12V)
Hi!
First, a gift from a friend, after mine hit the ground in a rather unlucky manner. Means really a lot to me, because I really love these. And props to Festool for also looking for one for me, but sadly they are gone.
A second package came from Germanys oldest, still manufacturing/producing file factory - by their own account. (http://www.feilen-leist.de )
I ordered 6 quality workshop files (150mm) fitted with quality handles (110mm). And a set of 6 quality warding/key files in a tin box.
Set of quality warding/key files in tin box.
Quality workshop files.
Flat cut 2 and cut 3 150mm/110mm
Triangular cut 2 und cut 3 150mm/110mm
Half-round cut 3 150mm/110mm half-round side
Half-round cut 3 150mm/110mm flat side
Round file cut 3 150mm/110mm
The first impression I have of them is really good. Quality product, great communication/service and fast delivery. I absolutely love the fact that I can combine any file length with any handle length.
Now I have to use them to say more about them. ;)
Third package was a really necessary flat suction pump. (Kärcher SP2 Flat) It can start pumping and will pump water levels as low as 6mm and will pump until theres only 1mm left. This is necessary "liability insurance" for a project that is coming closer every day with large steps.
Kind regards,,
Oliver
Those were nice Oliver!
Would you please share where you ordered them? I followed the link, but couldn’t find that they had a web shop?
The fact that you can order the length you need, and top it with a wooden handle is just great. I definitely would like the small set and a few larger ones.
Regards,
Stig
Hi Stig,
just E-Mail them, they get back to you with a price list and TOS. They sell directly to end users, but they don't have a designated online shop.
Kind regards,
Oliver
Well, that’s kind of nice. I’ll certainly do as there’s only very very long files with even more horribly large plastic handles available. One very seldom hold a file just by the handle.
It certainly looks good with those wooden handles as well!
Thanks!  [smile]
A Woodpecker Slab Flattening Mill arrived today. I ordered it before everything shut down & with all that has gone on I had forgotten about it. It arrived before they had stated it would. I believe when I ordered it, they said it would be delivered the 1st part of June. Woodpecker took a lot of care in packaging it. It arrived in great shape. Assembly was easy. I am very pleased with how well it slides. Now I need to get a planer bit ordered.
I just received 4 Anza Elite Felt rollers that have been highly recommended for yielding smooth finishes. We'll see how they work.  [big grin]
On the other hand, I've used these Purdy Parrot Mohair rollers before and every time I've had dismal results.  [sad]  [mad]
[attachimg=2]
I think this is the first time I have seen this WP item set up, other than on their website .  That looks really well-made and a good design. I'm also a bit envious of what appears to be a large shop.  [big grin]
On the other hand, I've used these Purdy Parrot Mohair rollers before and every time I've have had dismal results.  [sad]  [mad]
[attachimg=2]
From my experience, Anza’s look just right, Purdy’s not so much - if near spray finish is the goal.
The right paint/lacquer and technique should yield near spray paint finish with Anza.
