- Oct 16, 2015
A little set of hex drivers and a mag strip to store them on. I seem to keep reaching for the 4mm a lot, so a little quicker access can't be bad.
Chris Wong said:derekcohen said:I was at my local borg (Bunnings) today and came back with a 1/2" thick heavy smooth rubber mat 600 x 1200mm.
This will be great for my workbench when assembling furniture.
I hereby present Derek with the award for the Least Interesting Product Picture in this thread![]()
Tools & Stuff did a review of 4 cordless heatguns including a Milwaukee here:rvieceli said:[member=25351]rst[/member] please let me know how that heat gun works for you. I’ve been thinking about it.
Ron
rst said:Will do Ron, I've been thinking of this for a while, Acme sent me a $20.00 off so I bit the bullet. Had to get the transfer pump as I will be travelling to St Augustine, FL as my daughter bought a condo that needs a new hot water heater and I'll need to drain and replace with an on-demand. Have my Transit filled with everything that I can think of along with my painting gear as I can't be sure what all I'm going to need there.
ChuckS said:$1 Cdn a piece...goo spreaders:
Not just regular glue spreaders for me. I thin out the stiff tongue of a couple of them, and use them to push glue into cracks, for example, in a repair job.
When I have a complex glue-up to do, I put several of them on the assembly table so I never need to worry where my spreader has gone in the middle of the job.
thudchkr said:Just received a Mafell KSS40 today and put it to work on the deck I am currently working on. I am very impressed with it's power, smoothness and weight. My decking material is S4S+Plus Cumaru, very dense and hard. This saw cuts through it like butter. I previously tried using my Festool HKC55 and it cut much more slowly and was leaving a rougher edge. The HKC also weighs considerably more than the KSS. I then switched to a stand mounted Dewalt Miter Saw which worked ok, but actually cuts the Cumaru slower than the KSS. This also required carrying the heavy decking boards to the saw for cutting. With the KSS, I am able to place by boards, mark them for the required cuts, and then cut them without hauling them back up to the miter saw. And if I need to trim one, it's a piece of cake with the saw mated to it's mitering rail. The miters are spot on, matching the 45's I've been drawing with my speed square, and mesh together nicely on the deck surface.
woodbutcherbower said:[member=297]Michael Kellough[/member] 'T-Max' is the name Mafell give to the standard 2nd-gen T-Loc Systainer. All of their equipment still comes in these.
Been looking at that saw and I'm just surprised at how small & compact that thing is. That appears to be a perfect saw for decks & trim. The Flexi-Guide being able to be stored in the Systainer is a bonus round.
[member=2575]thudchkr[/member] Curious if that comes in the old Systainer or the new SYS³?
GoingMyWay said:I took advantage of Lee Valley's Veritas Seconds Event last week. I picked up a skew rabbit plane and a medium shoulder plane.
