What to do with two guide rails that are out
Boski
I have 2 x 1.4m Festool guide rails that are both out by about 3mm.
I have since bought 2 x Makita rails that I use.
I’m at a bit of a loss of what I should do with them? Bin them, keep them etc.
Does the router guide rail run on Makita rails?
I do have another Festool 800mm rail I can use for that I suppose.
How did you measure their bend? If it's a kink at one end, you could just cut the rail just before it starts to skew.
Well it was a long drawn out painful process with the TSO parallel guides , which turned out to be my rails.
I could try and see where its out and what length will be left, good shout, what would you cut them with?
3mm is a LOT over 1400mm. Are the ends touching when you join them together? That can cause issues, as the ends might not be square and it prevents the rails aligning.
Where is the deviation?  Is it on the long side or in the angle at the cut across the short end?  If the long side is good, recut the end to 90 degrees.  If it's on the long side, is there a bend in a short section that you could cut out and get a couple of shorter sections?
Again, on a flat piece of plywood/MDF, strike a line along the cut guide.  Flip your rails end over end and see where the bend is.  You can rock it back and forth like you would a normal straight edge checking a surface.  If it's a shock deformation, it'll likely be very localized with most of the rail still straight.  You can cut your rail around both sides of that bend.
It'll be rare for it to leave the Festool factory with a full gradual bend that's more than the
Place against a long straight edge. If the bend is a gentle curve, straighten by epoxying to a substrate, such as 3mm MDF or Ply.
Hmm. In my shop, I'd use the Kapex and my aluminum cutting blade, with the blade speed turned down to 3, clamped on both sides firmly.
I think you meant to say one side firmly.  [big grin]
It is both rails unfortunately, I didn't check them when I got them and only come to light when I couldn't get the TSO parallel guides to work.
Thanks will investigate and see what I can salvage.
I'm taking a look at that blade now. Not cheap, and I probably won't use it a lot, but I'm guessing its always handy to have and will last a while.
Keep in mind as well that the one part that is supposed to be straight is the top rib, as that is what actually guides the saw, router, etc.  The part of the rail next to the splinter guard is neither guaranteed straight nor should be relied on as such, which is why the recommendation is to leave on the splinter guard.  The back side of the rail can't be guaranteed straight, either, but it should be more coplanar with the rib than the splinter guard side.
Also, since the splinter guard is pliable and can move or fall off, it's not recommended to use that as a reference surface for determining straightness.
Nah, I clamp both sides and keep my left hand a little farther away from the blade that way.
It's one of those things where you might not use it much, but when you *do* need it, there's nothing else that'll work. TBH, I'm never stoked to cut metal on the Kapex, so literally anything I can do to make the experience less frightening (i.e., clamps, using the correct blade, etc.) I'll absolutely do.
Wait what?
Guys, you are really overcomplicating.
1) Ideally, you need an aluminum blade for your TS 55/TS 60 but an MDF/Chipboard blade will do wonderfully for a few cuts. Forget about the Kapex for now.
2) You needs to use a piece of offcut *), bout 8mm thick to support the rail (you will cut it placed upside down)
3) Take a square (GRS-16 works great, but any will do) and aligh your rail on the rail you want to cut (the "bottoms) of both rails will be in contact
*) if you had 3 rails, a better aproach is to use the second rail to "complete" the one you are cutting. Two rails upside down create an even board-like assembly and are a non-issue to cut with a tracksaw, no complications needed, and you can use your "standard" MDF/Chipboard blade for this if it is just a single cut ...
