leakyroof
- Mar 23, 2011
The Rigid has the two functions and lots of fans. It's a winner for small space requirements and the price has always been good.
I went with the Benchtop Jet Unit, the JBOS-5.
Plenty of power, very quiet, and the spindle selection is a wide range up to 3" diameter if you hunt for that largest drum and its sleeves which is not standard with the machine.
Dust Collection Port is sized for vacuum hose sizes with a 2" port, but I recommend using a 4" adapter to connect the sander to a larger shop DC system if you have one. Dust Collection works very well for me with this set-up.
The table tilts and is easy to adjust. There are a number of throat/spindle plates for the different spindle diameters that you would end up using.
Downside , not a light unit if you need to pop one up and down for limited table space in a shop. Lots of metal, cast iron top, and an oil filled drive mechanism add to the weight too.
Spindles and plates store on the sides of the sander in factory brackets.
