First of all thanks to all the contibutors who make this site a goldmine of knowledge for the enthusiastic DIYer I am.
You'll quick see that English is definitely not my mother tongue! I apologize for all those grammatical errors and hope to be understandable.
I don't own any Festool tool yet (except the handy VisioTape made by BMI).
I'm ready to make the jump in the next few weeks for the simple but very versatile LS130 sander for complete French-style doors and windows renovation as well as thick coated ceiling paint scraping. And I don't see any competitors.
Next -maybe in the meantime- I will also make the plunge, but for what?
I've been using circ saws for years and the hefty Makita 235MM/9.25in has become my do-it-all saw. It's plenty of power, can handle big rips and crosscuts (supports till 250MM blades not 10in!) and finer tasks (love to use 184MM/7.25in CMT ITK thin-kerf 1,3MM blades, rip or crosscut)
The main criticism is not the weight but I want something faster and lesser cumbersome to setup to achieve accuracy, something easier on panel cutting and maybe more than anything a "dustless" or "dustfree" enclosed device.
Since I want powertools that stay accurate, robust and reliable over the years and since I want to avoid any "aftersale regrets", I've narrowed my choice down to 3 models: Mafell MT55CC, Bosch GKT55GCE and of course Festool TS55REBQ.
After reading this forum the bare saw unit to choose would be the Mafell over the two others. But not fully decided yet. And with what? It's a global system after all.
Track:
The Bosch/Mafell seems to be "the straighter" when joining sections, is of a lower profile than its rivals, has two grooves for clamping (one closer to the cutting edge), main supplied lenghth 160CM is longer than competitors ;
while the Festool is more universal, compatible with Bosch/Mafell, Makita track saws, has more attachments for other tools and accessories, sticks better by itself, accepts Festool quick clamps.
I want to use my router (Bosch GMF1600CE/MRC23EVSK) with the track. I know there is a rail adapter (which is a trammel too) for Bosch routers to be used with their previous rail system. Is this adapter compatible with Festool rail? Or is there a new router adapter for the current Bosch/Mafell rail ?
There are also Festool's routers rail adapters but they don't fit Bosch routers, do they? Microfence is too expensive for my budget.
Is it worth to buy more than a single rail? I mean sliding a rail along a simple aluminum profile/stud is possible when reducing 250CM/10Ft panels.
Miter:
The Bosch/Mafell Miter attachment seems better to me for two reasons: while the Festool is a protractor, the Bosch/Mafell is more a bevel adjuster: the distance between two angles is longer hence the accuracy. And this attachment is a little rail by itself (what length exactly? 12in? 16in?)
But it needs a pricey Bosch/Mafell connector since this attachment must be mounted end-to-end as a rail extension for long cuts/long-reach cuts.
On the other side the Festool is cheaper and can be mounted on the main track.
Clamps:
I've never used a track saw and feel paranoid about rail slippage (especially in case of routing).
When I see the hundreds of quick clamping actions I do operate on a project it's simple: the more I use them the less I can live without them!
And I see Festool provides quick lever clamps (Bessey) for their tracks.
Is there a chance to use those Festool quick clamps in any of the Bosch/Mafell rail's grooves ?
If too thick is it worth to grind them ? Maybe yes for light clamping, making them useless for other applications. Costy.
Or use the mafell "jaws" with the Festool lever handles if they can fit.
On the other hand Bosch/Mafell offers only basic screw clamps.
Do those mar material surface as conventional screw clamps?
I also understand that rail clamps (whether linear lever or circular screw) are one-hand operated since the "head" is held in the rail's groove making them all quick. Lets call them the quick and the quicker, hence the irrationality to choose a whole track saw system based only on the best clamps to be used.
So in the end what would be best choice ?
Focus on a single brand starting from the chosen saw ?
Choose a whole system where every part equals: saw=track=miter=clamps=future attachments=future tools ?
Or mix Mafell saw with Festool Track, miter and quick clamps ?
Buy Festool quick lever clamps and a compatible rail (Festool/Makita/or cheaper) and build a subbase and a blade cover for my circ saw ? Messy but I keep the 1,3MM kerf and also the ability to use a wide variety of blade sizes and applications.
Thanks for your help.
Track:
Miter:
Clamps:
