I am getting the Festool 495717 parallel guides to help me cut panels from 600 mm wide boards using a TS 55.
Can anyone tell me if the 800 mm guide rail will be long enough to comfortably fit the parallel guides when working on a 600 mm wide board? Will 100 mm on each side be enough? I currently have the 1400 mm guide rail and will be getting either the 1000 mm or 800 mm guide rail together with the parallel guides.
