Will it fit? 36mm x 5m inside of Systainer 4
roncruiser
I got a good deal on Craigslist for a 36mm x 5m antistatic hose. The newer type Festool hose. The thing is monstrous. Will it fit inside a Systainer 4?
Thanks!
Ron
With inner dimensions being 382Wx266Dx285H you get about 0,9m per turn. I have an old style 3,5m 36mm hose and it's 46mm external and was sold with pipes and floor brush in inlay in a Systainer IV. If I remember right it fitted above the inlay in one coil. Without inlay and with a partial 2nd layer in the coil the new 36mm 5m hose should fit. But I've haven't done it.
Thanks.
Still not quite convinced.  Yet  :)
I have to do some more research.
My 36 mm x 3,5 m hose in a sys 4. It fits very easily.
You can add one more coil on top and then there's still all that space in the middle.
If you figure out the right way to coil the hose in, I am sure you can store that 5 meter hose in there.
In fact, I got 5 meter of 36 mm hose in a sys 3 (THREE). Tight, but it fits.
Besides my 3,5 meter hose I have a Y-split hose for my CS70 but I hardly use it, so I took off the 36 mm part which is about 1,5 meter, and use it with my cyclone on my Midi vac.
I got both the 3,5 and 1,5 meter hoses together in a sys 3. There's only one pair of connectors.
[attachimg=2]
