Woodshop Concrete Slab Question
Grakat said:
You can also spray water onto it for about a week, that helps the slab retain its moisture while it cures. I just poured a 20' X 12' slab and cured it that way. It's now been down for about a month.
Soon I will put the shed up on it.
There are curing agents (liquid spray on or brush on) that are better than water.  I don't have any names still lurking in my memory (after all, I am only 39 so have not had time to pack all that stuff into my head).  I think they can be gotten in small amounts all the way up to a tanker load.  They are good as dust barriers as well as curing agents.  You can find out more from your concrete supplier.
Tinker
It might not crack, concrete expands and contracts with temperature changes. I would imagine the temperature swings aren't that great by you. Look at basement floors, concrete counter tops, or any concrete that in a temperature controlled environment. I would probably cut control joints in after your done with the pour, cause depending on the jointer your finisher uses it could be a pretty wide gap.
What I just did for our new shop was grind down the concrete to expose the aggragate. Then we put down a hardner, and sealer
