[member=1674]Peter Halle[/member] I know this post about the Workshop is from a long time ago, but I have a question (with some background to explain the question). I have a Workshop 3000 and had been using it to sharpen with great success. Recently, though, I started hand sharpening with diamond stones for the coarser grits and waterstones for the last couple of steps. I have flattened the backs of my chisels better than ever before using 4000 and 8000 grit waterstones. If I take a chisel flattened by hand and then try to sharpen it on the Worksharp, the back of the chisel gets scatched because the "heatsink" on the Worksharp uses a 1500 grit piece of sandpaper. Based on your experience with the Worksharp, do you have a way of getting around this. I was thinking of buying very fine sandpaper for the heatsink (like up to 10,000 grit wet/dry if that exists) but doubt that sandpaper that fine would actually help hold the chisel in place while sharpening which I think is the purpose of the little squares of sandpaper Worksharp directs to be mounted. Have you run up against this problem? If so, how have you solved it? I love sharpening with the Worksharp because it's so fast, but the results are much better using a Veritas MKII guide and diamond and waterstones.
