jmbfestool
Kodi Crescent said:jmbfestool said:umm no I would adjust it every day! As I have my bench on site in a different place every day and most jobs dont have flat ground so I know ill be doing alot of adjustments and thats why I like my Spring Idea!!!
Being able just to place the MFT on the ground and the legs self adjust to the ground is quick easy and saves alot of hassle and I would buy one or even two if they made one like that.
JMB
It seems like you are talking about 2 different things, at least from my perspective. You could get a leg leveler add on like the Little Giant ladders have. This would allow you to place the table on uneven ground.
Adjusting the table to different heights is a different story though. I believe there have been ergonomic studies as to whether people really use the adjustments on their equipment. When asked if someone would use the adjustments, many say "Oh, yes! I'd adjust it every day!". When researchers go into the field and measure these adjustments over time, they find that the equipment really doesn't get adjusted much, if at all.
One of the very difficult things relating to product design and research is "how much do you listen to the customer?" Customers will tell you one thing, but observation tends to prove something different.
I agree and disagree! I agree that work shop lads will not often alter the height of the bench. Site lads will! Well I will any way I will be altering it every working day! Every time I set up my MFT I will adjust the legs to suite the ground. Most people drives paths gardens are never perfectly flat so I always have to keep moving my MFT around till it stops wobbling around as I have said the current one foot adjustment is to little of adjustment. I think festool either has to make a decision to go for the easy levelling type of MFT or go for just the height adjustment bench or make both sorts! Or design something kind alike my idea! which will do both and please both types people!
JMB
