Back at you Woodpeckers [wink] It was going to be a while before this was available in the UK and also no doubt even more expensive with the exchange rate and taxes.
Here's mine based on Ola's design and re-mix by Woodpeckers. I made a few design decisions:
1) Shim under the Domino to alter the height as I prefer the repeatability aspect of using fixed shims.
2) Used Microjig dovetail groove for clampling.
3) Used the dovetail track for attaching the square rather than separate holes, which seemed finicky.
4) Added stops on the T-Track so you can setup multiple positions and quickly flip between them.
[attachimg=2]
Here's one for the Woodpecker fans:
And, if you're a hater:
[attachimg=3]
I machined the square out of POM on a Nomad 883 CNC machine. The table is made from HPL (solid phenolic), and the mounting holes and Domino cut-out were machined with a Shaper Origin. Microjig Matchfit grooves routers on Jessem router table, using 8mm clearance pass, then the micro jig special bit for the dovetails.
[attachimg=2]
[attachimg=3]
