arso_bg
- Jan 6, 2008
Well, I'll keep it short.
Whatever method you use to square the MFT fence to the guide rail you might find it necessary to micro-adjust the position of your fence. If you are not lucky this can be difficult. I use a very simple jig to help me to accomplish this task. It is just a piece of wood with two 20 mm dowels. You need also a threaded insert a bolt and a nut. I think the picture is self-explanatory, so I will not explain here how to make the jig.
The distance between the centers of the dowels is 96 mm so they fit tightly into the table top of the MFT behind the fence. The final setup you can see on the second picture. When your fence is placed in position you can wind the bolt until it touches the back of the fence. Tightening the nut will prevent the bolt from moving. Now if you find it necessary to adjust the position of your fence this will be an easy task.
Regards
A.G.
Regards
A.G.
