Slartibartfass
- Apr 25, 2014
After I bought a third MFT/3 recently and switched them around to have them abutt on the long side I got tired by the stock table connectors that block off the usage of the front profile opening for clamps and other stuff.....
Looking at the MFT/3 profile realized that there are other openings that could be used.
Had to grind down the existing stock connector width-wise a tad to make it fit. Also had to use two connectors welded together to extend long enough to be able to use the screws from the bottom to lock into place due to the corner MFT/3 profile shape....
