Jmacpherson
- Jun 9, 2016
Strange question but hear me out.
I bought the mft3 because of its ability to fold up (strangely it is still deployed since setup) and that I can use it for multiple things.
Used it to clamp pieces this past weekend for sanding which worked perfectly and used it to clamp pieces on top and in the T-groove on the side for planing too.
Then we come to the rail. I had some squaring issues naturally but between all the posts here, online videos and using parf dogs I managed to square the rail. I checked it with 16mm melamine board and everything was good.
When I tried to work with thicker material 36-38mm that isn't as wide as board material, maybe only 113mm things started to wrong. As soon as I raised the rail and rail clamps it went all wobbly which I was expecting from all the posts. I used a second piece to support the rail and made my cuts.
The first 2 pieces were the right length, the 3rd one was off my 1mm. The problem with the structural timber I'm using is the thickness varies and I'm not sure if that "upset" the rail.
I decided to rather hang the pieces off the mft and use HKC/FSK combination instead of the TS55 and everything was 100% accurate.
I bought my HKC55 first and then the TS55 later because I needed narrow pieces on the waste side.
This brings me to my question(s) and conclusions...
Tracksaws are meant for breaking down sheet goods originally.
In theory does that mean the MFT3/TS55 combo is also meant for thinner boards and not thicker/narrower material like I was doing which is actually meant for a mitre saw?
The HKC55 is marketed as an handheld mitre saw and worked perfectly at the task.
I tried using the parf dogs stand alone with the rail but they weren't too happy with the narrower stock either.
Therefore was I using the setup for something I shouldn't have been and therefore am I to blame?
