LostInTheWood
- Jan 23, 2011
The "loose" cap for the dust bag was annoying me, so I thought I would fix it in place. You can peel back the bag from the frame by first unraveling the wire loom holding the ends of the frames together. I chose the lower one as it seemed the easiest to access. Once separated, collapse the frames in the bag and they will slip out of the zippered opening. I then got some thin gauge sheet metal and attached it to the top of the wire frame where I wanted the cap to sit. To secure it I rolled the edges around the frame and added a bead of hot glue underneath. I then glued a magnet to the inside of the cap. Now I can just throw the cap on the bag and it stays put. The last pic shows that you don't have to add any sheet metal, you can just stick the cap to the wire frame.
