any tips or trick to doing crown
thanks to all the replys! i did one the pre assembled route- worked great! just nailing them together was really tough. i wish i had the 2p10. anything that i can pick up local that is close to the 2p10 stuff? i would like to have this done before the 4-5 days shipping would take me. here is a pic of one square done.
i think this stuff will work as an accelerator for regular superglue (cyanoacrylate)
http://www.parts-express.com/pe/showdetl.cfm?partnumber=340-630&utm_source=google&utm_medium=cpc&utm_campaign=pla
check at local art supplies stores and or craft stores
i would reccomend trying to find a gel type superglue (keep it away from the finished edge of the crown to prevent squeeze out)    you might even be able to get away with just superglue and no accelerator although it will take slightly longer to set up.
Tite Bond also makes a 2 part superglue
http://www.titebond.com/instant_bond.aspx
check with local tool shops, lumber yards and wood working stores
Looking good!!!    keep the pictures coming
CA glue, the big box stores have it. Just takes longer than 10 seconds to set.
finished this up the other day. setting up a board for the spring angle was a great help also. thanks again guys!
I do a lot of Crown Molding, and my 2 cents would be ;
Laser Tape Measure - Take all your room measurement at one time, and jot down your cut list.
Check all your inside and outside angles to make sure there 45 ish  ;D....adjust cuts as necessary
Figure where you want to start and end, in regards to making your copes least visible.
Make your cuts a tad strong, so you can get a spring fit !!
2p10 is your best Friend  ;D
Dave
Mattdh,
did you end up using any glue? if yes what did you use and how did it work.
the crown came out very nice!  what a great looking room all together
John
i did- end up using some ca glue along with wood glue (saw that in a fast cap video) from my local wood working store.it worked out great once i got the hang of how much of everything to use and got my time down  with the glue and stuff. thanks!! its an 8x10 refrigerated wine room i prob put some pics up soon in the project section.
glad you got it to all work well..  thought it was a wine room but i had never seen holders like that before.. neat      definitely post completed pictures
