WarnerConstCo. said:
It's a 3 hour job to pull the door, do the ledger flashing, do the sill pan, cut the siding back and pop the door back in.
Flash the sides and top of door and install some Miratec or PVC trim where the siding was cut back.
You like expensive tools, but want to be as cheap as possible on the largest investment of your life, your house.
I hope you are compensating the individual for his time when he comes out to give you an opinion.
And another 3 hours to redo the interior trim, paint and caulk etc..
Listen, you need to understand one thing. I am ANYTHING but cheap when it comes to my home. I approach it with pragmatism..Like I said earlier in the thread, the inside of the jambs, and header are all flashed from when I put the door in two years ago. I fully expect that if I pulled the door those areas will be dry and fine. Only thing I can do further is expand them out after cutting the siding back further I suppose. Which means I am only pulling the door to address the jamb/sill intersection. Which if you were on this job I could show you why I think that..
As far as whether I pay this fella thats my business. But..It's a childhood friend, who runs a very succesfull constr. company, who just called and said there is no reason I can't bend a piece of flashing, then run it up underneath, essentailly tap it into the space between the slider and sill and run the wall legs up higher and then seal it from there. Not saying I agree or disagree with that, but thats one opinion from a pro thats had his eyes on it.
There is ZERO rot up at the sill, or near the door..The small amount of rot was a result of incorrect deck flashing that trapped water and allow it to wick into the plywood and is located down in the area closest to the ledger. No rotting or water damage up closer at the door sill area. If anything I would think folks would have hit on the subject of the deck ledger being removed!
I am not saying taking the door out isn't the best way to handle it, I am just leaving no stone unturned before I commit to that. I still think I could cut the siding back wider, remove that brick molding, do what my friend said at the sill, then come down over it with Vycor that is connected to the to both wall of the house and the patio door edge/jamb on both right and left sides. THen run a new piece across the Header..Then, I could reinstall piece of Kleer trim board or the like, back bevel that 90 corner off the inside jamb sides, and reinstall the trim pieces.
Capeessh? ; )
