Bench Cookie Storage from scrap acrylic
jg24
I had some scrap acrylic so I turned it into a Bench Cookie holder.[attachimg=2]
[member=6610]jg24[/member] - that's what I call inspiration to get organized while many are restricted with moving about.
I also think its' a helpful post for woodworkers who never had occasion to work with plastics, acrylic and otherwise. The right blade or cutter and a whole new set of possibilities for fixtures, storage, etc.
With a FESTOOL GECKO slippery plastic can be handled well using track saws.
Keep it up - and thanks!
Hans
I used to be in the custom acrylic business.  You can us the exact same wood working power tools to cut and shape acrylic.  The one exception is maybe use a plastics blade for a table saw.  Right now I do not even have a table saw.  So, I used the standard TS55 track saw blade to cut this 3/8” cast acrylic.
Side note acrylic shavings go every where, and are very staticy.
Yes, and how did you finish the edges. I've heard there is a trick to using a heat gun or torch to do this but don't know the details.
I will have to research the YT University course catalog and see what's available on the subject. :-)
xedos said:
Very cool.
What did you use for adhesive? Weld On 4.  Acrylic is general bonded together.  The Weld On (MethyleneChloride) causes the two surfaces to melt together.
Mapp Gas torch.  You just have to be careful and move the torch at a nice even pace along the edge.
Nice job!
I have one of the same cookie sets.
