Bluetooth adapter is good but can be improved
Mike S said:
A Class 3 device would be like the Bluetooth LE devices, like my heart rate monitor straps, the Apple Pencil, and I bet even the Apple Watch.
ben_r_ said:
mwildt said:
Gotcha, good post.
Worked with Class 1 and 2 devices, but have any of you ever even seen a Class 3 device?
Scratch that, I meant Class 1.
I don't suppose the action of the modules, and the 4-pin connector, work as simply as a large enough draw to power on the vac. Not that I was thinking about wiring the connector up to a grounded plug and seeing for myself or anything like that. No sir.
Not at all thinking about a solution for those of us with CT Minis/Midis.
I figured out how to do it, but it's not straight forward and is going to take some experimenting to finalize it.
If I can be of assistance with testing, let me know. I have hooked up a remote plug, but it requires having one of my Ryobi chargers and NiCd batteries hooked up. I could probably do something with an incandescent bulb fixture, but I'm hoping for something a bit more elegant. I've not had any luck looking for a bluetooth plug that draws a load.
Hey Rick, chalk me up for being your first customer... [cool]  very    [cool]
Yeah, I'm a little more "elegant" than that.  [big grin]
This one is so far "outside the box" that I'm surprised I even took the wild guess to get past proof-of-concept. But it took me 20 hours to stop giggling like a schoolgirl after I discovered it.  [tongue]
Is there anybody that know if this is Bluetooh 4.x (BLE) ? Are they actually paired?
For those thinking of the MIDI/MINI...
A plug that that goes in the socket (with a BLE transceiver), could trigger a load that triggers the auto start. I'm only not sure how much load the vac needs to start. The standard remote could then be used (if you can mimic the signal).
Nice work, did you take pictures of what the front panel looks like from the bottom after you mounted the bluetooth modul?
Took apart my ctm 36 hd's front panel, as it has all 4 switches it has little room for it unfortunatly, but i was surprised to see that the whole pcb is potted in epoxy, so no dust or water can damage it, let alone static electricity from anything.
I’m a bit late to the chat...
Bought one of the new midis with Bluetooth.
Now trying to figure out how to reverse engineer it so I can use it on my old midi.
Anyone worked it out yet?
Would love it to be Bluetooth and connect to the button remote but maybe has to be rf??
Anyone worked out what load turns on the extractor?
Need to do this!
Need to do this!
I sold my old midi (which was pretty new) and bought the BT version.  Anyway my thoughts where this:
1. Use a corded power tool with some variable speed. Hook up a amp meter and see on how many amps it triggers.
2. Depending on how many amps (and watts) it needs to switch on, design a plug with a BLE chip.  This way you just stick the plug in and it would trigger the auto power on.
3. Now you still need to reverse engineer the protocol (should be anyway public standard so you could use it between different brands, that aside).
Of course a option is to get into the inside of your MIDI, but thats another ball game.
$0.02
…working on it.  Would you be willing/able to help with some debugging?
I can charge my phone (18W charger, so 20W load) without the vac turning on, on the new Midi I. But I can't charge a 12V battery at 4A without it turning on.
Shane Holland said:
I'll bet the diameter of the bluetooth button is the same as the blanks on the front of the CT for a reason...
Because M22 buttons, indicators, potentiometers and switches are a worldwide standard?  [tongue]
