Bosch GET75-6N to Festool CT26 adapter?
KitShickers
Hello all,
New to the forum.  I was hoping someone would know of an adapter that will work to connect my Bosch GET75 to my Festool CT26.  Any advice would be greatly appreciated. Thanks in advance!
I believe the Bosch VAC024 adapter will connect to a Festool 36mm hose, according to the description I found, that adapter may be included with the sander. I don't know if it helps, but the dust port adapters on my Bosch Colt router fit my 27 inch Festool hose without any other adaptation. I use the VAC024 adapter to hook my Bosch miter saw to a FT 36mm hose (assuming I'm remembering the part number correctly).
Welcome to the FOG :)
I thought the Bosch dust connection was the same as Festool at around 27mm, which means the hose that comes with the CT26 should work. The Bosch sander also includes hose adapters. My Bosch Jig Saw connects to the Festool hose without an adapter.
Imemiter said:
Looking at you OF 1010!
Amen.  Try one of those 3D printed adapters for the oval ports.  The one I have is from ToolCurve, it's fantastic
Thanks for the reply guys.  I have the 27mm hose so I should be good to go it sounds.  THanks!
