leakyroof
- Mar 23, 2011
Pyrotechnic Cartridges are definitely in modern vehicles since you want to tighten the belt on an occupant in a crash and prevent them from sliding under the belt towards the floor as well[called seat belt submarining]tjbnwi said:Some thoughts and info from reading about the Bosch.
I don't see how skin sensing by SS is enforceable. We've had touch lamps and other touch sensitive devices long before SS was available.
I believe what the items from the other division are the cartridges that force the blade below the table. They are nitrogen cartridges that come from the Bosch automotive division. The cartridge is used to lock seat belts in an accident.
The Bosch does not jamb the blade or use blade motion to lower the blade. It uses the charge from the cartridge to rapidly lower the blade.
The cartridge fires, the seat belt tightens and you get to replace the whole assembly after a crash since web stretching of the belt material is a very real possibility along with the one-time usage of that cartridge.
