Brines M10-A10 MLT Speaker Build.
These should be much easier to implement...
Quilted maple about 3mm thick.
iamnothim said:
Wuffles said:
Can you get a photo of the re-saw with your third hand please? I'm curious. Not about the third hand, that's a given, but about the re-saw.
Like this?
Oh hello. NO HANDS!
Beautiful work.
The resawn quilted maple has been applied to one carcass.
[attachimg=2]
Cheese said:
Why did you have to vacuum bag the burl but not the quilted maple?
Hi Cheddar
Veneers are 0.50mm thick.  They are wavy with bubbles and do not lye flat.  The re-sawn quilted maple is 3.0mm thick and board flat.
As such I can use clamps and a caul.  If I bagged the assembly without the sides the press would crush it.
The sides get tiger maple veneer.  I will bag those before assembly.  Note in the photo small index blocks to keep the veneer in position while cauls are aligned and it is loaded into the bag and .  The blocks are applied with a dab hot melt glue.  The back also get's veneer but will be assembled before the veneer is applied.  With the sides on, the assembly should be stout enough to bag.  I'm debating it.  I would hate to come out and find a bunch of pancaked boards.
I like the idea of the index blocks alot. As soon as I saw the little blocks I thought "he's making his life easier"! Using the bag without the blocks could be a hit or miss situation.
Sparktrician said:
That's going to look spectacular once you get the finish on it.  Good choice!
I hope you are right [member=7493]Sparktrician[/member].  aka Sparky
(Every electrician I've ever known was nicknamed "Sparky")
The quilted has a very faint pink color, where the tiger is just white.  Hence, I think it needs a dye to equalize the color and make the grain pop.
The formula I used for the craftsman lamp is General Finishes water based dye.
2 parts Light Brown
1 part Amber
1/4 part Cinnamon
It's the dark part on the test board.  The light side of the test board is diluted by half.  I like it lighter but the Amber came out too strong.  So I will cut the Amber in half and see what I get.  I've also used the same recipe except substituting Orange for the Amber.  I prefer a touch of the Amber tone.  I tend not to like straight brown.
I with top coat with Deft satin finish.
Comments and suggestions are always welcome.
I learned this from The Master Paul Schurch.
Cheese said:
Also Luke, what are you using for glue, and is the same glue used for both the bag and the caul method?
For burl I use Pro-Glue powder because burl is porous and this glue doesn't stain as much as wood glue.  However I Hate The Stuff.  I've tried both mixing methods and there's always drama with clumps.  Even with a drill and mixing paddle.
Note:  It was a darn good thing I took the burl off.  I neglected to sand the finish off the plywood and over time, based upon how easy it was to remove, it would have lifted.  Again, I knew better but I always get crazy during glue up.
With the tiger maple I will use Titebond III.  The veneer isn't porous and the application is much easier.
[attachimg=2]
2 tiger maple veneer sides bagged using Titebond III.  Plastic mesh sandwich with top platen.
This should give much better results.
Re: Gap between veneer and face.
I can't figure out how to make a bezel that would look decent.  I have a set of Mohawk Finishes wax fill sticks.  I could shoot a coat of finish then fill with a wax color that is close.  The leveling scraper works great.  Either way there will be a noticeable ring.
Ideas???
Ideas???
Bearing guided bit in a router?
I looked.  A bevel will make it worse.  I could try to make the hole large with a flush bit, but I don't like the risk reward...
Many, many, many moons ago I fabricated some stainless rings for some JBL slot tweeters I built. I liked the contrasting stainless and black look.
[attachthumb=1]
