paulhtremblay
- Jun 4, 2014
My brand new TS55 created burn marks in 19mm MDF when I made narrow cuts with the parallel guides. It did not create burn marks when using the other side of the parallel guides, or when using the rails by themselves.
I contacted Festool support. At first, Lester suggested the toe was out of alignment. He suggested I could test the alignment myself, get a replacement saw, or return it. When I told him the burning only occurred with the parallel rails, he changed his original diagnosis, stating that there was nothing wrong with the mechanical workings of the tool. He put me through to applications.
The guy there (sorry I forget his name), asked me if I used my left hand when I made the cuts, and if I cut behind or beside the saw. I told him I used my left hand (thought I am right-handed) and and walked beside the saw. He told me I must be tipping the saw, and that the saw was meant to be pushed from behind.
Since the cord and hose were getting caught in the rail, I first had to make a jig to keep them out of the way. (I hope to post picts of this device.) I wanted to have both hands on the saw so I could concentrate on the cut.
Tonight I tested the saw using Festool's suggestions. At first, the saw struggled to cut 19mm MDF. It made growling noises and acted as though I cut through 8/4 hard maple. I saw burn marks in the thin strip of MDF. The burn marks were lighter in color and did not run the entire length of the board, but I could still see them. I tried a few other techniques, such as removing the dust plate, making sure the bevel was at 0 degrees (and not -1), and having the MDF hang over the edge of my cutting table. The burn marks seemed to lessen.
Then I put the dust plate back on, and cut with the MDF completely on the cutting table. I noticed that the if I put my body behind the saw, it did not struggle to cut through the sheet.
Finally, I bent my torso so it was squarely behind the saw. My head was directly over the saw, as if the saw were a gun and I sighted it. The saw glided through the wood. The burn marks completely went away. I ripped 18 pieces of MDF 50 mm wide. With the right technique, the strips had no burn marks at all and the saw moved easily along the cuts.
The proper technique seems to be to really get your full weight behind the saw, so you sight over the top of it. Doing so makes a huge difference.
