jmbfestool
Tim Raleigh said:IMHO, I would replace it and redesign (not drastically) it so that those beams that are touching the cement posts are clear of standing water/moisture and more resistant to rot.
Even if you patch it you will never be happy with it, you will still incur the wrath of the local historical preservation board or whom ever has their eye on this structure and the Vicar will go ahead and hire someone else to repair your work.
It's a nice project, I hope you get it.
Tim
Yes I agree I did mention it to the vicar. Their is some sort of water proof membrane between the wood and stone the problem is water will jst run between the two so it wont be doing a very good job any way. I was thinking of putting a groove all round the bottom like 10 mm up and then putting lead around to bottom into the groove? OR maybe covering the entire bottom and 5/10 mm up the side with some sort of tar or tanking kinda paint/fibre glass? Also I know you dont treat the wood but I was thinking of doing the joints treat the insides of the joints tenons mortises with something as Guy Ashley, John said no glue can be used so water can get inside the joints like it has done and rot the tenons.
JMB
