I'm in the process of building some cabinets for the master closet and I'm building LED lights into them. For the fixed shelves the wiring is an easy activity. For the moveable shelves (via LR32), not so much. I've seen Cort's thread where he very cleverly powered the shelf pins however, at the scale of my project, I'd end up with many hours of work to do the same thing. Such effort wouldn't really benefit me much and would likely only be for the next owner considering my shelves won't move much once initially set. So I'm attempting to come up with a simpler, though likely less slick way to hide the wiring.
My current thought is to use some kind of a maple wire loom or channel that I could tuck into the corner of each cabinet. Yes I'd have to notch each shelf and potentially re-connect a shelf to wires each time it's moved but I can live with these downsides dice the fab time becomes nearly zero. So two questions:
(1) is anyone aware of maple (colored) u-channel or loom that can be purchased?
(2) any other interesting ideas? I thought of using the flat wire (made specifically for LED lights) and painting it...
