I spent all day reassembling the CMS router module that I brought over from the UK and converting an MFT 800 into a router table.
There are a lot of components in the package, and the instructions are typically less than helpful. Nonetheless, most of the parts only fit one way.
The router module is very heavy. The central part of the fence alone weighs almost 3 kg. The base plate is 7mm thick aluminium. I can imagine there is no vibration, even with an OF2200 mounted in it.
Despite being almost square, cutting an opening in my MFT 800 for the base plate proved to be very difficult. I know that other FOGgers have looked into doing this, so I can say that the end result is worth it, but it took a long time to get there.
The problem is that the edge of the base plate is three different thicknesses in places. The short sides are 7mm thick, the front side is 5mm thick, and the rear edge is a cove-shaped 18mm thick at the deepest point. There are also a couple of corners rounded off.
My widest rabbet bit is 1/2" so I used my TS55 to cut a square hole in my MFT top 1/2" smaller than the base plate. My hole was deliberately off-centre so that I could have as much space as possible in front of the fence. It is also slightly to one side to avoid having an edge cut through a dog hole.
I then routed the various depths on each side. The rear edge is the hardest as there are actually two lips, and the top one is quite thin.
All in all, I was quite happy with the result and the base plate is snug and level enough with the MFT800 for my purposes. With a little tinkering I may improve it a little bit.
Tomorrow I will assemble the fence and test drive the router in it.
[attachthumb=#]
[attachthumb=#]
[attachthumb=#]
