Considering Buying a Shaper Origin
I am seriously considering purchasing the Shaper Origin, but am concerned about my relative lack of other tools. I have done a moderate amount of woodworking in the past, when my dad had a full setup in his barn.  I have no access to that at this point and have most of the smaller tools, but no table saw, no planer, only having a mounted miter saw and drill press. Is it reasonable to expect that I could make use of the shaper without these tools or would the lack thereof significantly negatively impact the use of the
Shaper Origin.  Not sure how this forum works or if I am in the right place, so thanks for putting up with this! Hope this finds you all excellent!
I'd seriously consider what it is you want to make before buying one. An awful lot seem to be for sale constantly on the Shaper Facebook groups because people didn't use them anywhere near as much as they thought. I'd take a look at the Shaper Hub and ask yourself if the type of projects you see are what interests you. Invaluable when you need it, but very expensive to have sitting around gathering dust, especially if there are other tools you could spend the money on.
I use mine as a small router, so cutting small recesses, hinges and hardware, or if I have something where I want a specific layout pattern of holes for mounting something. It's great for the accuracy in these situations rather than free-handing with a standard router. I've also used it to make MDF templates for creating parts out of solid wood using other tools such as the bandsaw and router table. I also have the workstation but haven't used it for mortise and tenon or dovetail joinery.
It's also been used for my daughters DT project which required 43 pieces of plywood to be cut to form the shape of a hedgehog. An ideal tool as after a little tuition I was confident she was safe using it. It did however take 8 hours to cut all the parts! Pretty impressive to see how well it manages in a total novice situation and gets some level of hands on work compared to school DT class that is literally press send to issue the G-code to the CNC.
If you want to cut sheet wood to make cabinets or bigger projects or general around the house DIY etc. Then some of the other tools you mentioned are probably going to be more useful.
In my view, the Shaper Origin is a bit like a Leatherman Multi tool. It is incredibly useful, but at least for me, it is typically not the perfect tool for most work. It is essentially a CNC router with the ability to be used on both large and small work (not specifically limited by table size etc).
If you can give more details about your projects, or the types of applications you intend to use it for, I am happy to share more thoughts.
As [member=66875]simonh[/member] said it depends a lot on what you plan to make.
I have used mine for a variety of things.  This ranges from complete projects like found on ShaperHub, making templates, and many things that have curves.  Some of these need the ability to mill the wood before bringing it to the Origin, it depends on the specifics of project.
It is expensive, but I am happy with the purchase (maybe acquisition is a better word given the price...)
Bob
p.s. If you get one, I also recommend the Workstation.  I use mine a lot.
I agree with the advice above: it depends on what you want to do.  It took me a little while to appreciate mine.  Now I use it all the time, but in a supporting role mostly: making templates, fixtures, & jigs, mortising for hardware, etc.  It's a brilliant tool, but it's a little slow.  Making a non-trivial project from start to finish with just SO would be excruciating for me.  Things like auto-pass, workstation, and plate improve productivity, but they also increase the price significantly.
I've had mine since the first release ~2019-ish and can't image not having it in the shop. That said, it's not the best tool to start your WW career with.
Wonderful toy that can seriously expand your game, but there are so many other foundational tools that can get you further.
RMW
I have had mine for several years, at this point, and it has been a great addition. The newest updates and accessories have really streamlined the process. I use it for all kinds of things, from templates, hardware installation, engraving and joinery.
Like Richard said, it's an "add-on" type tool, to be used with other tools. It's not really much of a stand-alone tool.
It's not a "production" tool. A normal flat-bed CNC is much more capable there.
Shaper Origin....
I don't have a table saw either, but I do have a way to break down sheet goods.  If you're looking to cut cabinetry for instance out of a sheet, note that at $26/roll of tape, you'd get one 8'x4' covered.  That's a lot of overhead to eat up.  For small nicknacks, the Origin with Workstation could work well enough coupled with a jig saw.
But without a planer, you're relegated to sheet goods only.  The surface you're riding on needs to be flat.  If there's a cup, it'll throw an error that the 'tape has moved'.  I don't think any solid wood you get S4S from a box store is going to work outside of the Workstation.
At the very least, I'd get a Bosch 1617 or a comparable router and make yourself a small rudimentary router flattening sled.
Things are going to be slow, (and painful when you make mistakes), but it's doable for the hobby woodworker.  More so if you're interested in doing inlays and fancier stuff.
FWIW, I use my Origin *all* the time for inlays, engraving, joinery, specially-shaped parts, production runs of odd parts, and did I mention joinery, joinery, and joinery...? It's the only tool I haven't had even a moment of buyers' remorse. Between my Origin, track saw, router table, and domino, I barely use my table saw any more. I just built a prototype barn chest and didn't use the table saw at all. Can't even remember the last time I even thought about dragging my miter saw out of the corner.
You can do a LOT of stuff without a table saw in particular. That's not me ragging on a table saw; I love having a nice one, but it's definitely reduced in daily usage for sure.
Food for thought.
There are a lot of guys out there who use a bandsaw, rather than a table saw.
That and/or a track saw can do pretty much anything.
It's all about what you make and how fast you need to be. Some work-arounds might take a little more time, but still get the job done.
As others have suggested it really depends on what you intend to build.
I looked at an Origin for a few weeks and was close to purchasing one. Then I started looking at flat bed CNCs and decided that was a better route for me. I ended up with a OneFinity Journeyman. It’s been a great addition to my shop. I did 8+ hours of cutting this week. But I still consider it an add-on. Before getting a CNC I got a planner, jointer and table saw. I build cabinets, vanities, shelving units, closet organization and lots of face frames. Planner, jointer, table saw get lots use in my shop with the table saw being the most used. The CNC is great for certain projects but it is not an every project tool for me. When I use the Journeyman I typically set it up to carve and start the job before lunch or dinner. This allows many jobs to complete while I am away from the constant noise of the router and dust collector. Building an enclosure to help with the noise and dust from the CNC is a “someday I will get to that project” for me.
