russ_1380 said:just had another play with it.
I adjusted the rail clamp on the saw and re cut the plastic guide. The results are a little more accurate now.
It seems ok for crosscuts under 1 foot, which is good enough for me. Anything longer and the amount that its out is noticeable by a large degree.
For the money it seems an ok fix where accuracy isn't the be all and end all. And thats all you can expect for that money and a hand tool, so no hard feelings. If on the other hand the Dewalt square had some slight adjustment capacity it would be ideal.
As a mini review I'd say don't bother with one and save your cash. Worth a try though, cheers Steve.
R
Charimon said:IDEA an FS 400 with integral square.
Thanks Craig
Charimon said:ON TOPIC
I think the best way to do it is:
1. for your 90 deg stop use alum 1.1/2" wide 1/2" thick by 10" long
2 rout or mill a 1 17/33 wide slot (triming just the bottom protrusions, rubber and al,) at 90 deg on the bottom of your "Shorty" rail about 5 " up from the starting side
2.1 drill and countersink 2 screw holes in the rail with matching holes (taped for #8 by 32) in the stop.
3 mount the cross bar
4 check for and adjust for square by the cut and flip method
5 when adjusted secure with with industrial mounting CA glue
Thanks Craig
jander1960 said:I know this is an old thread, but this reply belongs here...
For a quick, accurate cross-cut (as someone mentioned above, a couple of 2x4s), how about the BenchDog Pro-Cut Saw Giude. Seems to be just what the Dr. ordered...
Bench Dog Pro-Cut (available at Rockler and others)
The first time you use the jig, you cut it to fit your saw (like the edge of a guide rail). I haven't used this, but it looks perfect for the task.
Anybody out there used the Pro-cut with their TS saw?
jim
rnt80 said:JMB, I was hoping I'd hear someone state this. I cut into my 1400 a couple of weeks ago and have meant to cut it down as well. I'm ordering a new 1400 and as soon as it gets here I'll chop the old one in two.
Wonderwino said:If you have more than one rail, the easy method I use is to line the back edge of one rail up with the edge you want to square to. Then butt the rail you will cut with square to the end of the first rail. Drop in a framing square to check it and cut.
Easy & Fast. Smart?
Charimon said:. . . a short rail with a 90 would be huge . . .
