 - Oct 8, 2007
My ct 33 was acting a little sluggish and letting some dust go at the tools. a look at the vacuum gauge I have on my blast gate confirmed the obvious, 2.5'' vac. I popped the top open and, whooa! Overload, (though nothing new around here)
The bag had filled to its gills and yet the suction was still sufficient to keep pulling. It pulled the intake out of the socket and filled on top of the bag and proceeded to cake the filters, then fill the 50mm hose to the blast gates and partially fill that too!
The ct is a massive performer even when stuffed to the gills. The dust is primarily solid surface, very dense and heavy. The bag weighs about 40lbs when filled.
One thing I'd like to point out and why I took pics is look at the motor area of the vac. It is pretty much spic and span, clean as a whistle, virtualy dust free even after sucking dust like this for 8+ years now. These units can work in some incredible and demanding conditions.
I had burned thru 6 other vacs in a few short years before I put in the ct. 2 actually caught fire.
I'm sure others have enjoyed this bag busting overfill, but for those who are contemplating a new vacuum and wonder why they should go for a ct vrs another, heres a few pictures to reason over.
[attachimg=2]
[attachimg=3]
I did some vacuum checks on the hose sizes and heres what I came up with If your wondering.
hose only:
empty bag 50mm hose 9'' 36mm hose 8'' 27mm hose 7''
full bag(very) 50mm hose 3.5 36mm hose 3'' 27mm hose 2.5''
my blast gate loses about 2-3'' (might be time to seal up leaks again)
the bigger the hose the more vacuum ,but lower velocity. the smaller the hose, lower vacuum but more velocity.
Bill in seattle
[attachimg=2]
[attachimg=3]
hose only:
Bill in seattle
