Rod, what are you using for a collection container?  I just picked up the ClearVue CV06 & have now destroyed two trash cans!  First I hooked it up to a rubbermaid brute trash can, which I thought was perfect.  It collapsed like a tin can, from the 134 CFM of the CT33.  Then, I went & got a galvinized 10 gallon trash can.  This, like the first can, worked well at first.  Then I noticed the performance drop & found that the seams had seperated.  The can is now wrapped in duct tape, which works, but it looks like a mummy can.   ;D  The CT33 is a beast.
  I plan to try a Fiber bucket next, yet who knows?  What did you use to build your Tornado Cyclone?  How 'bout a pot belly stove.   ;D
  BTW, you're right about the bag remaining empty this way.  I'm doing alot of routing with the OF 2000 & the waste is plentiful.  I purchased the ClearVue CV06 because I was filling a CT33 bag tight with just under 100 lineal feet of routing 3/4"w x 7/8" w dadoes.  Both machines are fantastic performers, yet the cost of bags concerned me.  The "Tornado Cyclone" works amazingly well.  Now if I can find a worthy container.........
-John
				rodwolfy said:
			Bill,
I don't know what kind of a work environment you're dealing with, but have you thought of a cyclone separator? I bought a Clearview mini-cyclone last month after reading several recommendations here.
When I got it home, I threw out my old shopvac motor and mounted the Clearview on the old Shopvac (which has wheels) and then made a new lid out of plywood. It is amazing how much of the extremely fine dust that goes down the Clearview and not into the vacuum. I used it first on my Fein with a HEPA filter and couldn't even get a pinch of dust. I was just thinking that if you are dealing with a large capacity of dust, it would be much easier to pre-filter it into a larger shopvac container or barrel on wheels and then empty that, instead of changing out the Festool vac bags?
Rod
