CT-SYS on the Kapex and track saw
ear3
New York, NY
Has anyone tried the CT-SYS on their Kapex, and if so, how much dust collection does it sacrifice vs. a normal Festool vac, due to its lower CFM?  I've found myself needing a second vac for the occasional site work I do, but due to storage constraints in my shop, as well as the hassle of hauling around a second vac, have so far held off.  But If I could park the CT-Sys underneath my Kapex on site, that would be a great time saver.  Also, is it like the Mini or Midi where you start to lose suction as the bag fills up?
The alternative when I'm on-site would be to keep my CT26 tied in to my Kapex, and use the CT-Sys for other things.  Does it work well on the track saw?  I probably wouldn't do this, though, since I assume the CT-Sys would not handle so well, say, the chips created by a router.  And I tend to do a lot of on-site routing.
EDIT: Since the CT-Sys has yet to be released in NA, I guess I'm calling upon my friends across the pond to field this question.  Or maybe there are some NA users who have snuck the vac across the border.
Will the 36 mm hose fit on a CT-SYS. I believe most agree that the 36 mm works better with the Kapex. I have a 36 mm I Use with the Midi on my Kapex.
Yes a D36 hose will fit the CTL-SYS.
But there's no angled adapter for the D36 hose available, however a D36 hose will never fit the hose garage of the CTL-SYS.
Dust collection on a SCMS is probably the hardest tool for efficient dust collection and the CT-SYS the weakest Festool vac.
I don't use Festool vacs because even the big ones aren't powerful enough IMO.
I tried the Bosch GAS 35 against a CT36 with 36mm hose on a few tools. The Festool has air flow of 3900 l/min; Max. vacuum 240 kPa of pressure and the Bosch 4,440 l/min and 254 kPa of pressure. I was expecting these figures on paper to be insignificant in real life. Being only 13% less in flow and even less with only 5% less pressure. However the difference was plain to see in the Bosch leaving noticeably less saw dust behind.
So for the above reasons I think the CT-SYS with only 3000 l/min and 200 kPa would be a bad idea for a mitre saw. Also I think the CT-SYS's limited dust capacity would become wearisome on a mitre saw that creates a lot of dust and is a workhorse of any workshop/site. I think the CT-SYS is ideally suited for sanding, Domino cutting, small clean up after drilling, etc, but not heavy sawing.
I just checked the Festool 2016 catalog and there is a long life bag for the CT-SYS.  Cost is $80 which equates to about 20 bags at current pricing.  I could see that being a viable (emptied often) option personally.
I personally don't like the longlife bags and am surprised Festool even manufacture them!
A lot of fuss is made about health and safety, HEPA dust collection, size of micron particle collection, etc. Then apparently go and open up the bag and shake all the dust out and end up breathing it all in and getting it all over your clothes, even worse if there's a slight breeze, not for me.
I just want to open up the vac and pull the tab to seal the dust in the bag and throw it away, then put a clean bag in.
Everyone has their preferences.  I guess why there are different types.  I empty my bags sometimes standing upwind.
I live by the sea and "upwind" is a very fluid and swirling concept. [big grin]
I think you guys talked me into buying one. Glad someone asked about this situation. I'm going nuts with my Ridgid vac not fitting my domino or TS55. Ever since I got my MFT3, my new Bosch 12" glider miter saw isn't seeing much use so I'm not worried about the dust collection on that thing.
So the hose that comes with the CT-SYS will fit the port of the TS55 but what do I need for that tiny domino dust port?
[member=19296]TheMarvelousOne[/member] Do you know about the Fein Step adapter?:http://www.amazon.com/Fein-STEP-ADA...1?ie=UTF8&qid=1459806201&sr=8-1&keywords=fein+step+adapter
Also, Bosch makes an adapter that might work connecting the CMS to the Ridgid Vac, though it might have to be used in combination with the adapters one can get from Home Depot in the vac section.  I use the smaller diameter (1 7/8?) Ridigid orange hose to connect my Kapex to my CT.
please excuse my ignorance but I'm still trying to understand these Festool vacs before I pull the trigger and spend $550 on a MINI.
Is it all about the CFM? So a $120 shop vac that claims a 168CFM can perform better than a $550 CT Mini that has 137CFM?
I'm guessing the Festool motor is built better and has more features but just curious about the performance and ability to collect dust.
Something to keep in mind, most tool manufactures exaggerate performance statistics, some by a large margin.  Festool seems to be more conservative with their statistics.
Festool vacs have the auto tool trigger feature and are very quiet.  The $120 shop vac screams and doesn't auto trigger.  Also you need to know Festool vacs come with a small diameter hose.  The small hose works well with tools like sanders, the Domino and other smallest power tools.  For tools that produce more dust and larger chips a larger diameter hose works much better.
If you do decide to buy a Festool vac, I suggest you buy local so you can easily return the vac with Festool 30 day no questions asked return policy if you aren't happy.
Sometimes it is just about raw CFM, though.  When working in my shop I have my Kapex tied into my 6.5HP Ridgid vac (with a 1 7/8" hose), which I find does a slightly better job than the CT26 with the 36mm hose.  But as mentioned, no autostart and somewhat louder -- though the muffler option on the Ridgid vac does make some difference.
There are two key parameters: volume of air which the vacuum can pump through in a minute (measured in CFM or liters per minute) and water lift (measured in mm or cm or inches as height of the water column which a vacuum can lift). The first is a measure of volume without load, it is measured at the inlet of the vacuum without a vacuum hose. Any resistance to air flow would decrease this parameter. The second is a measure of vacuum without volume, it is a measure of how high water would be lifted in a hose if you dip end of the hose in a bucket of water.
The trick is that both of these parameters are lab-type characteristics. You never use a tool with a completely open or completely closed air passages. You are always in between. You always get lower CFM than written on the paper. By how much lower - depends on water lift, diameter of the hose, and size of air passages in the tool.
If you pump air through a large diameter hose and use it for dust collection from tools which generate lots of dust but do not have effective dust collection shrouds and do not have significant obstacles to air flow, you only need CFM. CFM would not drop much if you use a 4" vacuum hose and wide open air inlet on the tool. A $70 shop vac would beat Festool. A Jet vacuum can have 500 or even 1200 CFMs and will exceed Festool almost by a factor of 10 when it comes to collecting dust from a table saw where sheer air volume and air speed are needed.
If you pump air through very narrow passage ways, e.g., in a sander, and if you use a small diameter flexible hose, you need a lot of water lift to create enough vacuum to get air through them. You do not need much air flow. This is where dust extractors come into play. They have a different turbine design and they typically have twice the water lift of standard shop vacuums.
Hence, for a table saw, a shop vacuum (any brand) generally performs the same or better than any dust extractor (be it Festool, Bosch, or Fein). Typically, you get around 180 CFM from a $50 - $70 vacuum, and this is more than Festool.  All dust extractors are rated around 140 - 160 CFMs.  This is not hard to beat. In contrast, for a sander, a dust extractor will beat any shop vacuum by a wide margin. No shop vac can get even close in water lift.  For tools in between, e.g., track saw, it is a wash, and there may be some small differences in performance of turbines in dust extractors from different manufacturers.  Overall, this is the application where creature comfort features (noise level, auto on, hose rigidity and weight, etc.) come into play. No reason why you can't use a cheap vacuum for these applications.
As always, no tool is perfect for all conditions and all tasks.
For the track saw, you need a long and flexible vacuum hose. Dust extractors excel in this area. With Kapex, you can use anything, as long as you use 36 mm hose, preferably short. I used a Ridgid 12 gallons vac from the Home Depot which I got for $69 and found no visible difference in the efficiency of dust extraction. Hated it because of the noise and because one has to turn it on separately. You forget it, and your Kapex is all covered with dust, and you are covered with dust as well. Eventually, I replaced it with CT26 dedicated to the Kapex. I saw no measurable improvement in dust collection, but much nicer operation.
Not sure why you would want a Mini. It is almost the same weight as Midi,  same specs, but it has a much smaller dust bag capacity. Storage space is the only advantage that comes to mind as is is a little shorter than the Midi.
I agree with this assessment completely!  One of the main reasons I purchased the more expensive Festool vac for shop use, was for the HEPA factor.  When I considered the longlife bag, all I could envision was compromising the sealed nature of the dust containment system.
When the bag is full, all I want to do is lift it out and throw it away, just as I do with my household HEPA Miele, and why I did not buy a plastic bagless Dyson for home use.
Awesome info! Thank you! I know this has been covered before but whats the point of a forum if you can't interact. Sorry for all the repeat info but I really appreciate the response. I'm not really looking at a Mini, just using a cheaper model for example.
I pre-ordered a CT-SYS today, this will help with my 2 festool power tools (domino, TS55) and I'm just a hobbyist so doesn't see a lot of volume. Just the comfort of having the hose fit the tools will make my shop time a lot more enjoyable. While I was researching the I-socket & iVAC, I discovered the CT-SYS has the auto mode which made the purchase even more exciting. Can't wait. Will use the Ridgid vac I have for my Bosch miter saw. Now just need a solution for table saw/jointer/planer - 4" tools.
A quick search finds the following:
Rigid WD1851 is 47" and 199 CFM.
Festool is 90" and 137 CFM,
Bosch is 97" and 150 CFM
General 2hp DC is 11.25"  and 1550 CFM
It's all about the right tool for the job but I would still take the "shop vac" and 1.5-2hp dust collector with an iVac control over the "dust extractors" until my shop is full of all other tools.  I love my extractor, but there is money better spent elsewhere IMO.
With a cheap adapter, I can in theory connect a 50 mm hose from Kapex to Dust Deputy to CT36, but would the physics of increasing the hose diameter beyond 36 mm make any difference in the real world assuming a reasonable hose length?
Attaching a 50mm hose to the Kapex is not convenient. The slight increase in suction makes very little difference. However, because the 50mm hose is so stiff compared to the 36mm hose the performance of the Kapex is compromised.
I have been using Kapex since before they were sold in the USA. My shop has 6 Kapex with another near-new one reserved to go on-site for installs. I use less than 2m 36mm AS hose to dedicated CT22. By the way, you will be surprised that even when cutting most of 8 hour shifts Kapex do not generate a lot of dust. The 2 Kapex located in permanent spots in my shop also have conventional miter saw shrouds behind and below them attached to the shop DC system with 4" hose to catch the small amount of dust getting past the extractor.
