Steve Jones
- Dec 23, 2007
I had posted some pictures of my cutting table some time ago, but since some items have changed and a couple of folks asked me for pictures, i thought now would be a good time to show it again.
Some thoughts about it's purpose: since I spend most of my time cutting up full sized sheets of 3/4" plywood, this system is designed to enable me to cut full sheet goods efficiently alone (My business if building custom cabinets in a one man shop).
I don't have construction diagrams or pictures taken during contruction, but I think the pictures and description here will enable anyone to make their own versions. The table serves as my main assembly table as well (despite the fact that I have two other tables intended for the purpose, I find that you can't beat a really big table with enough room to flip and spin a partially assembled cabinet).
Pic 1: is the infeed table, a couple of folding stands with a plywood top, this is set up before a delivery so can stack the 3/4" stock (the heavy stuff) at the "infeed" end of my cutting table, each sheet can then be slid onto the "operating" table as needed.
(You'll see also some handy home made storage to keep some of the clamps handy, the hooks are simple plywood scraps cut into "L" shapes and pocket screwed to the end panel)
Pic 2: Under the table are several simple "drawers" designed to hold a systainer, this keeps all my Festools to hand (always within reach) and I find the added advantage that if their regular storage is this close I actually put things away between uses.
Pic 3: Also under the table is the regular home for my small compressor, primarily used for powering pin and brad nailers, this home means it also is close (I don't have to move it to use the nail guns) it's stored in the back side of the table (non work side).
