Ken Nagrod
- Jul 15, 2010
jvang said:when i cut for domino in the actual size it is the norm for me to maybe tap domino in. when i use the next cut for slip for edge gluing is when i can put the domino very easy and about 40% of time they can fall right out plus after glue up the face of the two pieces are not in line. so you know i even clamped the head with two c clamps and cut the slot so i could see if it was the way i was doing.... the results were the same as without the clamp. plus keep in mind the rep from the supplies did the check before he sent in and after it came back.
it has been dry here all winter and i have been inside here in east central illinois. i also keep the dominos in the plastic bag so they would not dry out or absorb moisture. the rep and i used both dominos the ones i used and the ones he has at his shop with the same results.
about the only two things i have not done is purchase a new bag of dominos and have not tried another 5 mm bit. plus keep in mind we had the same results with the 8 mm bit.
if anyone has another suggestion to try i am more than willing. i truly believe it is a wonderful system. the domino is the fifth tool i have purchased since september.
thanks
john
John,
I've had those issues too, with plywood. I think it's the quality and construction of the plywood causing the issue. At least I believe that to be the reason for my similar results.
