I've just tried to calibrate my new Domino XL using the additional guide I found through these forums.
Out of the box the alignment wasn't quite right, so i did the gauge alignment test on page 20. The bottom was around 1.5mm to the right, so I needed to move the sight gauge left, however the gauge was already nearly to the left with little room.
I've managed, with three hands, to hold the gauge hard left and scew it tight. This has improved it, but they are still consistantly around 0.5mm off.
I can make the odd one align if it twist the wood, but I don't think this counts. I never get one with the bottom line off to the left, which I would expect if it was central.
Is there anything more I can do to fix this?
I've attached an image of an example. It could be that as I'm new to woodworking, the engineer in me is looking for tighter tolerances!
Thanks in advance.
Robin
Thanks in advance.
Robin
