Mike Goetzke said:
1. I was just looking over the Domino XL Supplemental Manual and for 3/4" ply it recommends 6mm tenons.
2. Plus on page 17 it goes over the process of making shelf butt joints. It says to lay the shelf bottom side up on the side and make the mortises referencing off the base. Is my math incorrect or would this be 1mm short of blowing the mortise right out the bottom of the shelf (15mm + 3mm = 18mm)?
1. I think the statement you're referring to is on page 15. It reads,
"Choose a Domino tenon size to be less than or equal to 1/3 of the board’s thickness."
Because the 700 is made for thicker material, 24 mm and over, that would yield a Domino that is 8 mm thick.
The same applies to #2.
It's really best to use the smaller Dominos in 18 mm sheet goods. As noted earlier, Woodpeckers offers an option as does Seneca.
https://www.senecawoodworking.com/products/rts-500-cutter-adapter-for-festool-df700
https://www.senecawoodworking.com/products/1-2-domi-shim
