Ken Nagrod
You people are acting like crazy women during an 80% off shoe sale!
Don't knock each other over to get one.
[big grin]
[big grin]
andvari said:RonWen said:Tom Bellemare said:Bingo!VictorL said:I'd say $1000.
I guess that would be a great marketing strategy -- many, many would decide to own both models. [wink]
Crikey yes. $1000 and I'm in.
keithjfuji1439 said:You can set the depth of cut to a minimum of 15mm and buy some of the long stock Festool will be selling to custom cut 8x30 Dominos.
WarnerConstCo. said:Most people want to see the tenon all the way through, any issues blowing out the other side of the work piece?
Kev said:Wow - that's just absolutely rude to every other sucker country on the planet - $1975 base in Oz and our dollar is buying about 1.09 US last I checked. So for equivalence I'm paying over $2100 for that same thing.
Festool just made me a very unhappy customer.
Good for you US guys, but sucking the blood out of the rest of the planet to subsidies US market penetration has got to stop NOW !
woodguy7 said:Calm down Kev [poke]. [big grin]
John Stevens said:It's nice that the XL can be used for 8x30 tenons, but I'm hot for it because it can bore an 8mm tenon straight through a leg or stile that's 2" wide!!! Faster and easier to make through-M&T joints, baby! I couldn't care less if they're only floating M&Ts and not traditional ones.
John
Did not get it either. 70mm deep is 2 4/5" so you can cut through 2 3/4" stock. 8mm is the smallest bit, but there are 10mm (3/8") 12mm (1/2") and 14mm bits.GreenGA said:Because I have done very little traditional M&T construction, here is a technical question for those more experienced than I. [embarassed]
As John pointed out, the DF700 can bore an 8mm tenon straight through 2" wide material. Would the fact that they are floating tenons, John's description, make them any weaker, or stronger, than a normal/traditional M&T connection of approximately the same dimension?
If so, why? [huh]
John
RonWen said:My question, are all of the XL700 bits capable of the 70mm depth or are they (as with the 500) of various lengths? e.g. the 4mm bit is half the length of the others.
GreenGA said:As John pointed out, the DF700 can bore an 8mm tenon straight through 2" wide material. Would the fact that they are floating tenons, John's description, make them any weaker, or stronger, than a normal/traditional M&T connection of approximately the same dimension?
RussellS said:GreenGA said:As John pointed out, the DF700 can bore an 8mm tenon straight through 2" wide material. Would the fact that they are floating tenons, John's description, make them any weaker, or stronger, than a normal/traditional M&T connection of approximately the same dimension?
The loose tenons could be a fraction of a fraction of less than 1% less strong than a traditional tenon. With the traditional tenon the tenon is part of the wood with the grain running the same direction. With the loose tenon the tenon is glued into both pieces of wood. Grain does not match. So in theory it could be less strong. But glue is actually stronger than the wood, so it would not be much less strong. The problem with all the way through loose tenons is that the wood is a different species. Its a beech loose tenon. While the wood you are using is cherry, walnut, oak, maple, etc. So the Domino loose tenons won't match too well if they are a loose tenon. Concealed loose tenons, no problem. Exposed through tenons, wood won't match.
WarnerConstCo. said:So who is going to use this to make window sashes and wooden storm windows?
I don't really see the XL as a jobsite tool, which correlates with my, I can get a mortiser and tenoner for about what the XL would cost.
GreenGA said:Would the fact that they are floating tenons, John's description, make them any weaker, or stronger, than a normal/traditional M&T connection of approximately the same dimension?
I conducted an experiment with homemade spikes. this is what came of it ..Rick Christopherson said:GreenGA said:Would the fact that they are floating tenons, John's description, make them any weaker, or stronger, than a normal/traditional M&T connection of approximately the same dimension?
Floating tenon is the correct term, and it just means that the tenon joint is comprised of 3 members instead of two. With all other things being equal, unless the tenon length into the parallel grain is short, there is no difference in strength. With all things NOT being equal, sometimes a floating tenon like Domino can actually be stronger. Specifically, instead of a single wide tenon, there would be several smaller tenons with a web of material in between them. This remaining web of material keeps the two joining pieces stronger. Of course you can do the same thing with a traditional tenon. Another thing that improves the strength of a Domino tenon joint is how tight the mortise and tenon fit together. When the DF500 first came out, a lot of people complained about how tight the tenons fit, but didn't realize that this is what made them so good. Glue by itself has no strength. It is only the close contact of the joining surfaces with the glue, that makes a glue joint stronger than the surrounding wood.
