leer
- Oct 4, 2013
I made my own "super-sized" MFT-style top on a CNC router. Anyone making a top should either measure existing holes, or if you do not own an MFT (as was my case), I measured my Qwas Dogs, and programmed from there. I used a 1/2" spiral upcut router bit. I did a couple of test holes, found the perfect fit, and then milled the sheet based on those settings. It takes a few test holes, too, especially if your bit is ever so slightly undersized or oversized. You definitely want to get them as close as possible, and a little upfront fine tuning can make a big difference.
When I set my Qwas Dogs (and now Parf Dogs, too) into the holes, they gently sink in. Not too loose, not to tight. Any CNC shop should do the same, and if not, I'd find another shop.
