PeterK said:
Just received the Dust Deputy. Ordered the version with 2" inlet and outlet as the hose ends measured at 2" internal so thought that would fit. WRONG! I have the boom arm. What are you using to adapt the hose ends to the DD? Just wrapping with tape to snug it up? Found a slip on adapter? Thanks for any ideas.
Pete
I bought the 2" steel version too. It came with two adapters - one softer grey colour to snug onto the steel pipe - and one hard black which goes over the grey. The inside diameter of the black adapter is
very close to the inlet diameter of a festool vac - close enough that a festool hose stays in without futher adaptation.
Oneida supply the two adapters to be used on the pipe to the vac. I have used them on the dust collection pipe instead, and hope to get two more adapters to use on the vac pipe. I then intend to get a festool hose with vac connections on both ends, to connect the DD to the festool.
