ear3
Good advice. Thanks [member=4105]tjbnwi[/member] I especially like the piano wire trick!
tjbnwi said:Remove screws, this is where the glue will be holding the strongest.
Insert a putty knife between the panels to get a feel of what you're up against. Heating the knife may help. Piano wire will be an option.
A block of wood along the edge of the melamine panel, a hard sharp rap with a dead blow hammer. If you try this get some moving planet rubber bands to wrap around the top. Last thing you want to find out this worked as the piece goes through a wall.
Get back to us once you give it a try.
