- Oct 16, 2015
Hawkeye0001 said:It's always been around! Absolute recommendation, I run all my drills with them, makes a HUGE difference in handling and e.g. the BHC is still able to do several hundred holes into concrete with that tiny battery.
I never understood why anyone would run a 5 or even 6Ah battery on their drill
I don't get that either, though I use Makita drills and drivers, except for the CXS.
Although, I am in the static environment of a shop, rather than in the field, I just don't see the need for bigger batteries in drills or impact drivers. I used to run the 1.5ah batteries, but Makita has gone to 2ah as the minimum now. They will go all day (or longer) with a drill/countersink combo or driving 1 1/4" and 1 5/8" screws.
If I spent the day driving big deck screws or lag bolts, maybe, but do you really gain that much power from the bigger batteries? in a drill/impact specifically?
Sure, in the compact routers, or track saws, etc I know it matters, but drills/drivers?
Makita has an extra "tab" in the track mechanism of the higher amp draw tools that will not allow the lower amp batteries to fit onto them, though the reverse is not true. You can put the bigger batteries on anything.
I typically run the small 2ah batteries on the compact routers too, with the small edge trimming bits I use, and keep one 5ah battery for bigger bits. Though you have to be careful about bigger bits in those small routers. The locking cam lever does have not the strongest hold on height adjustment. If you keep the screw loose enough for the cam lever to work, it may not be tight enough to hold the body in place.
I have taken to tightening the 8mm nut after assuring the height is correct, as I have had to make repairs, because of slipping.
