Rob-GB
- Nov 7, 2009
The problem with 110v Kapex motors in the UK is that most transformers are underpowered in amperage. Try running a CTL-Mini + Kapex on one and it will slow down and refuse to cut efficiently, put them both on a better quality/larger one (also heavier) and it works just fine unless you are running off a long extension lead or plugged into a low amperage circuit.
On a wider field of the issue is that the UK still refuses to let site contractors use 240v tools on site despite the advances in circuit breakers and technology. An issue which causes huge conflicts, most of my kit is 110v but I can't get a 110v DF700 so I have to be further inconvenienced by not being able to use my vac with it the way I prefer or the way the Festool system is supposed to work, and have to buy and lug around transformers for domestic work and hope they have a socket on the electric cooker ring main.
Lost count of the times my plugging in a transformer has tripped the mains messing with peoples computers or cooker or washing machine.
I have a lot of faith in the quality of Festools which is why I have invested so much money in them. All tools have limitations and not all limitations are the fault of the manufacturer.
Rob.
Rob.
