Cheese
- Jan 16, 2015
deepcreek said:I've been looking for a good brad point set and had settled on the Fisch but needed a hole that was 1/8" (0.125) on the money and discovered that every 1/8" Fisch bit I tested at my local Woodcraft using my Mitutoyo digital calipers was undersized.
I do know that metal working drill bits are usually .001”/.003” undersized if measured at the chuck end. I assumed it was because drill bits usually drill a few thousandths oversize, a kind of built-in Kentucky windage. [big grin]
I’d suggest drilling a hole with the bit in hard wood and then measure the diameter of the hole, as that’s what you’re probably really after, an accurate sized hole.
