I am having problems fitting an ATF 55e handsaw into the basic 1a table.
1. It is always a struggle getting the handsaw into the sliding carriage. I have done this so many times now that I can maneuver the handsaw around until it fits. The problem is a gap of about 2mm between the hand saw and the carriage at the back of saw. Festool instructions say the washer should be directly behind the locking knob. Although it looks as if it would fit better between the carriage and the handsaw thus filling the 2mm gap. I am aware that the bracket plate connecting the front of the carriage to the rear is adjustable by means of 2 Torx screws. Using this adjustment I have reduced the gap considerably.
The problem now is because of the reduced front to back carriage distance the saw is even more difficult to fit into the table.
2. Another problem I have is setting the ATF 55e handsaw perfectly parallel to the table parallel guide. I cut a lot of melamine coated board using the 2 cut scribe and full cut technique. Because the saw is not parallel I get breakout on the cut edge. The carriage has 2 brass allen key screws at the rear to make the saw parallel. However they don´t seem to have much effect. I am measuring using a micrometer between the fully raised saw blade (back and front) and parallel guide. Afterwards I cut a piece of wood which will get cut first at the front edge of the blade and, if not parallel, again at the back edge.
Does anybody have ideas on how I can solve the above problems?
In advance many thanks
Malcolm
Malcolm
