jmbfestool said:brewster201 said:Thanks for all the good info and photos. I really like the Xcite gun and not too many issues with tip plugging. The 15C25 comes with a pump discharge filter and the gun has built in strainer above the swivel. This my setup with a Kremlin one pass heater
Oh sorry I looked at the gun and tried typed in filters and nothing popped up normally websites which sell the gun have tips and filters in accessories and that particular gun didn’t so asssumed it was just a swivel connection only.
Saying that the filter can’t be very big at all to fit inside there and it looks like it requires tools to remove and clean filter is that correct?
jmbfestool said:tjbnwi said:jmbfestool said:I go on.
The Kremlin Xcite has no inline filter so I believe you have a higher chance of tip blockage.
I’ve attached my gun and Xcite which has no filter
The black section of my gun houses a large filter largest filter in the air asssited market.
[attachimg=2]
The Kremlin gun does have a filter, it is in the fitting that the fluid hose connects to.
I have a Graco and C.A.T. AAA guns.The y also have filters at the gun hose connection. I have a second filter housing mounted on all my pumps.
I have had a few plugs, I do strain the product and keep the equipment clean. I make sure I flush the hoses well after use.
Yeah sorry the swivel connection gave me doubt due to its size and it not popping up with a quick search I made a quick assumption it didn’t have a filter.
Always expect two filters one at pump and one just before gun.
Block tips are very annoying.
Especially mid spraying a large panel![]()
jmbfestool said:[member=4105]tjbnwi[/member]
Got the little strainer in bottom of hopper then I use 100mesh in pump and 100 to 200 mesh in the gun.
Wagner have a chart and 8 thou to 10 require 200mesh
I don’t always flush mine out to be honest. If I’m using same product over a few days or week I leave it primed. Only till I know I’m finished or change product do I give it a proper clean flush through.
Just had another quick search Xcite doesn’t really come up with much really.
Found a non UK site selling filters I think are for the gun?
Still can’t tell if it’s tooles filter change.
I see didn’t know that. So they are a extra filter you can have in addition to your inline filter
So you can be super filtered.
So you choose filters based on product.
I choose tips based on product and then select correct filter for the tip which is stated by manufacture that’s how I thought you had to do it.
Finer tip = finer filter
jmbfestool said:JCLP said:Found on Kijiji a Kremlin 15C25 ( 15:1) pump with Xcite gun, couple of extra tips, pump fluid and some filters. The seller says it is 5 years old and has only sprayed water based clears through it. Looks fairly clean in the photos. What type of questions should I ask them and what test can I do if I were to move forwrd on this. His asking price is $2400.00 CAD and paid $5100 CAD 5 years ago.
Cheers,
JC
Wow. Too bad not available here in Canada.
JC
[member=24938]JCLP[/member]
Such a shame you can’t get Wagner.
Look at finish with the pump and gun
Cheers,
JC
tjbnwi said:BM Advance, sprayed with a 395 AAA.
JCLP said:I'm back. Can't stay away from this punishment. Needed a project so I built a new spray booth, 7'x7'. Was able to make air tight and I created an air chamber behind the filters for maximum air extraction. No fear of overspray going into the house. I posted a video on my instagram account, woodworking_by_jc.
Check it out.
Cheers,
JC
PaulH99 said:tjbnwi said:BM Advance, sprayed with a 395 AAA.
Did you spray these in place, or did you spray the parts and assemble after the paint dried?
JCLP said:Very nice Tom. Maybe I should get a Graco 395 Finish Pro II as well.
JC
