Wasn’t sure where I could/should post this request, hope here is okay.
I am replacing side mounted drawer slides in a dresser I made with longer ones from a different company. I replaced the cabinet member slide component with the longer slide but forgot I hadn’t replaced the drawer member yet. I connected the drawer with cabinet member to check if adjustment was needed and all worked well...I thought! I attempted to detach or remove the drawer and the lever locking mechanism will not release. Is there a way to disassemble the latch while the two members are connected so I can remove the drawer? I can press the levers but that does not release the two parts. The drawer member component is liberty and the cabinet member is Richelieu. I could leave it as is and the slides work but would need a magnet to keep the drawer closed as it’s not long enough to lock into the back. Don’t really want to do deliver the dresser like that. Any suggestions?
