HKC 55 EB review
Arvid said:
rst said:
Despite my not probably not really ever needing to cut a vertical 45% 2X4, I tried it last night...didn't need a chisel, just ran my razor knife over the nub...much ado about not much!  [smile]
Finishing a cut with a razor knife or knocking off the lip with a chisel will get old fast.
I guess everybody here builds square porches and decks and hardly ever need to cut multiple beams at 45.
Basically it comes down to festool being a trim tool for guys with small hands and mafell geared more toward framers and timber framers.
Or Festool  for the skilled cabinet makers - kitchen installers  and Mafell  for the  rough work. [big grin]
Hilti have just launched  the  21.6 volt  SC 70W-A22  cordless circular saw.
It will chop  70mm @ 90 degrees  and 51mm  @  45 degrees.
That means  for you guys in America  it will cut your  dimensional 2 X  lumber @45 degrees  because  its not really  2 inches thick at all.  [big grin]
Its some other size  which is  well below  the  51mm  thick  capacity  of the SC 70W-A22  when set to 45 degrees.  [wink] 8)
But Hilti don't seem  to have cottoned  on to these  clever rail systems  that  mafell and festool are using.
Maybe that's the saw for you Arvid?
Lbob131 said:
None the wiser.
My TS55  can cut through  38mm  on the rail @45 degrees. Which is the  exact  same  as the KSS 400.
Dude, is there some medication you can take to improve your memory?
Read your own reply #123.
Its some other size  below 51mm  thick.  [wink] 8)
Pay attention dude!
The Hilti UK site.
Okay, if you mean Hilti's rail is a "dumb" rail compared to the "clever recoil" rails of Mafell and Festool, I'll give you that. I don't think Hilti has the recoil rail yet.
A big reason this thread has gone on so long, to the point of deserving Svar"s comment, is that there are at least 2 parameters for at least two different saws being discussed (or argued about) and too few replies bother to specify which point they are addressing.
Here is the summary of this thread so far:
[dead horse] [dead horse] [dead horse]
Cheese said:
Lbob131 said:
Its so confusing.
Surely its  1 1/2" x 6"?
Yes it can be... [eek]
Just to add to this confusion, a 2x6 is actually 1 1/2" x 5 1/2". While a 2x8 is actually 1 1/2" x 7 1/4".
And you thought it was just our imperial measurements that were goofy.  [smile]
  Hah, good one...... [embarassed] [embarassed] [big grin] [big grin] [big grin]
feel free to move along then. many here are enjoying this discussion. if you don't like it you can ignore the thread.
We are not here for you. half the topics on here are beating a dead horse at some point to some people and others like to continue the discussion.
Michael Kellough said:
Lbob131 said:
None the wiser.
My  memory is fine thanks.  The 40mm  spec was from  my "NMA Agencies  LTD"  catalogue which  has a mafell section. Which is clearly wrong.
The 38mm spec is from the mafell website.http://katalog.mafell.de/index.php?IdTreeGroup=12962&IdProduct=30956
Looking into the mafell ks60cc.
Maybe a ks400 as well. I'll review them in the other brand tools forum.
I had a chance to use my new HKC 55 and the KSS 400 side by side today after work.  I only spent maybe an hour making some rafters from 2x4 scraps and miscellaneous cuts .  I'll need to spend more time with the tools to make a more comprehensive comparison that is fair to both saws.
Initial impressions of the HKC are positive.  As I mentioned earlier in the thread I have fairly large hands and I didn't find the handle to be a knuckle buster.  Also, battery life seemed pretty good.  I made maybe 40-50 cuts in 2x4s (1 1/2"x3 1/2" or 38mmx89mm) and the battery gauge still had three of three bars.
When I get a chance to use the two together more I'll try to find some time to post my thoughts.
I picked up a HK-55 today as well. I should have some time in the shop the next day or two, so I'll try to get some side-by-side pics and impressions of the HK-55 and the KSS-400.
Looking forward to these reviews. Tell me what you think of the blade guard lever action.
I noticed the little spring and cable that raise the guard a little flimsy designed. Also noticed when raised half way or if raised slowly it did not always come back down in the closed position.
You can see how it works when you remove the blade.
View attachment 3I used my HKC today to cut stair stringers for my daughters deck.  Fantastic  [big grin], I used the 420 rail set for one angle and the 670 for the other.  I had it hooked to a 36mm hose and vac as I was on my back porch working.  I had used two  regular FS 800 rails with dogs under the rails for positioning for the last two sets of stairs I made...this was much quicker and switching between rails was a breeze.
View attachment 1  View attachment 2
  I know I could probably get used to it, but I don't like the small knob that releases the Detent Lock on the left side of the Rails. I would rather see a spring loaded lever that's easier to use,. esp. if you've got gloves on.  Minor thing, but that threaded knob just seems a bit fussy to use.  Let us know what you think about that Rail detail Brice...... [popcorn]
The threaded knob is kind of fussy to use, because you are moving the detented stop with one hand while snugging down the screw with the other hand. However, I think it's something that you'll get used to over time, besides, you'll probably not be constantly changing angles but if you need to, I'd use 2 different rails as rst suggested. Like using one drill but swapping out one chuck for drilling and a 2nd chuck for fasteners.
Also, you do have to tighten the threaded knob at every angle setting because even if it's in a detent (every 15°) the smallest force against the rail will move the stop. [tongue]
.  Good thoughts, thanks [member=44099]Cheese[/member]
The cordless HKC 55 is perfect for framing, decking, flooring, roofing or other work when you don't want to worry about cords or plugs. It's the right tool when you need more time and less hassle.  from Facebook today.
How is it that a "perfect" saw cannot make the cuts described ad nauseum in above comments? I would post a comment on Facebook but it would likely baffle most of my friends.
There's no such thing as a perfect saw.
Festool is good. But so is  mafell  and  hilti.
looking forward to receiving my new HKC55 in the next couple of days...i'm an audio video installer, so the concerns about the compound-cut limitation on 2x doesn't bother me at all....i'll never have a need for that, but totally understand the concerns by some of the framers...to be honest, most of my needs will be for putting up blocking for TVs, light framing for exhaust fans, etc...probably overkill like a lot of other festool items, but the convenience and speed of the unit is appealing to me....and I'm already committed to the tool line-up and systainer system.
I have a TS55/MFT combo at home, but who wants to take that to a jobsite for the occasional rough cut?...i think the HKC55 should be fine for me.  I'll have a chance to put it to use pretty soon for some under-floor subwoofer platforms we need to build for a current project.
