gostauffergo
- Nov 22, 2013
I have had a CT26 with a compact cleaning kit for a long time, and I mostly use it to clean up on the jobsite. It works great but clogs often with odd shaped debris. I have a 36mm 11.5ft hose that fits in the hose bay as long as you wrap it up super carefully.
I want to switch to the industrial cleaning set with the 50mm hose, but I don't own any of them and are not sure of the functionality of the size. I'm not sure if I want a 8.5ft hose or a 13ft or what the storage would entail. My questions-
Does the 50mm 8.5ft hose fit in the CT26 hose bay?
The industrial cleaning set has 38" long tubes. Is there any type of systainer that will fit this?
Would a 50mm 13ft hose fit in any systainer?
Is a Maxi systainer able connect to the top of a CT26?
Thanks so much for any help.
John
John
